86WORX
Old 09-28-2020, 10:30 PM   #127
WildCard600
WildCard600's Avatar
Drives: 2020 86
I think the batteries operate in the cold, but the range is affected, which may or may not be an issue. The average person drives 30 miles a day. I don’t know if this average is lower or higher in areas of extreme weather. The life of the batteries could be affected too, but I am not sure. Regardless, the batteries in the hydrogen cars will suffer the same degradation if that is the case. Range shouldn’t be greatly affected like it is for EVs because hydrogen in the main storage system for energy.
https://www.google.com/amp/s/cleante...-cold-36c/amp/
It's not about driving the cars in the cold and losing range per se, it's about them sitting in the cold for an extended period, ie the batteries freezing and becoming uselessly damaged. If hydrogen vehicles suffer the same issues, the whole thing is a non starter unless you live in a temperate climate.
WildCard600 is offline   Reply With Quote
Old 09-28-2020, 10:33 PM   #128
WildCard600
Drives: 2020 86
Originally Posted by serialk11r View Post
Lithium titanate is good down to -20F and can be stored even colder I think, so good enough for most of the country. I think some of the experimental aluminum ion batteries can go to -40.
Aka you can park your Lotus Evija outside no problem
It gets negative -15f here sometimes and I live right on the mason-dixon line.
What country are you referring to ?
Old 09-28-2020, 10:39 PM   #129
serialk11r
Drives: '06 AM V8V Coupe
The USA? lol. Where does it get below -30? I thought even Illinois or Minnesota don't really go below -30. You should be able to store a lithium titanate at -40F=-40C.
I've only lived on the East Coast for 2 years but the coldest I saw was -5F in NYC and -19F in Vermont in mid-January 2019. 2020 winter was much warmer than that.
Old 09-28-2020, 11:02 PM   #130
WildCard600
Drives: 2020 86
I lived in VT for 24 years. I've seen -30 more times than I care to remember. I've seen -15 living right on the border of what is historically considered "The South".
Tesla states in their manuals to not expose the vehicle to -20 or below for more than 24 hours. I would assume because it damages the batteries or puts too much strain on the heating elements attempting to keep the batteries warm enough to prevent damage.
Old 09-29-2020, 01:25 AM   #131
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Then batteries in hydrogen cars would be just as bad. Im sure there is a solution to keep the batteries warm. The simplest solution is storing cars indoors.
Old 09-29-2020, 01:46 AM   #132
Irace86.2.0
Coincidentally, I ran across this article today. Not necessarily automotive related, but various infrastructure happenings.
https://www.bloomberg.com/news/artic...first-shipment
It would be interesting to know how they produce everything and capture the carbon.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Spuds (09-29-2020)
Old 09-29-2020, 02:16 AM   #133
serialk11r
Ah well, I'm from California, and the lowest I saw outside Tahoe was 27F in 20+ years Typical winter day around SF is like...55F.
I just did a little research, apparently Tesla's coolant freezes at -30C = -22F, but if you leave the car plugged in, it'll warm the coolant to keep it liquid. The batteries themselves can be stored safely at -40, but of course you have reduced power and no charging capability below 0C. Apparently they use propylene glycol instead of ethylene glycol, which stays liquid a few degrees colder.
The Following User Says Thank You to serialk11r For This Useful Post:
Irace86.2.0 (09-29-2020)
Old 09-29-2020, 03:05 AM   #134
Irace86.2.0
Emissions and fuel economy standards are completely different -_-
You can still buy a gas guzzling Mercedes G or Bentley today but those engines are very clean in terms of toxic emissions.
Koenigsegg badges don't make aluminum and steel magically lighter...the intercooler and turbo are going to be at least 50lbs alone, and even a carbon fiber crank case 2L long block would weigh well over 100lbs.
Yes, but the RX8 had the fuel economy of a V8 F150, while also failing Euro 5 standards, which means it is producing more emissions per mile than other vehicles in its class, so this is bad bad. For instance, it got 22 hwy at best and the 86 gets 34, so it take over 50% more gas to go the same distance, so whatever it produces in emissions, you could add 50% more emissions. The G Wagon is exempt from the gas guzzler tax because light duty trucks and SUVs are exempt, which is stupid.
Yes, Koenigsegg makes stuff magically lighter. One way they do this is through the use of exotic materials like titanium and carbon fiber. Another way is with 3D printing their turbos and other parts using a honeycomb structure like below, and also using variable geometry turbo that allows for a much smaller and lighter turbo than having a big turbo without the veins. In the case of the 3-cylinder, they are just using two small turbos sequentially I believe instead of one big turbo. Another way is with their Freevalve engines that lack cams, cam chains, cam gears, etc. and eliminates the need for a wastegate, precat on the exhaust manifold, throttle body and other things.
Old 09-29-2020, 03:34 AM   #135
WildCard600
Drives: 2020 86
Well, that's going to be an issue for a large percentage of the car buying public in cold regions.
I think I said earlier in the thread to purchase stock in extension cord companies. The future with plug in ev's is going to be hilarious.
Old 09-29-2020, 05:38 AM   #136
serialk11r
The RX8 had horrible fuel economy, but a rotary with higher rotor temperatures will dramatically reduce the unburned HCs and bring fuel efficiency near piston engines (at the cost of torque). It's been documented by Paul Moller's research. A mild hybrid system can make a hot running engine usable at low revs. If I ever have too much money, I'm going to have some aluminum side housings and zirconia coated titanium rotors made for the Renesis and run it at 11000rpm XD
Do you really think Koenigsegg Freevalve is much lighter than a cam driven system? There are separate actuators over each valve (which are very powerful because they need to open the valve in 1ms), plus the air source consumes a huge amount of power. He says "we can remove the throttle body to save weight", but throttles were never heavy to begin with. Likewise, do you really think the 3d printed turbo is that light? It's still a huge amount of steel. Also notice the crankcase isn't even carbon fiber.
The 70kg claim is probably the long block + the turbo + intercooler. It almost certainly does not include accessories, motor-generator, radiators, or the exhaust.
Anyways, yes electric motors should be able to get near 10hp/kg like Lucid Motors says with very high speed motors. Motorcycle engines do around 4hp/kg. Rotaries can do around 6hp/kg. If you need a very large amount of power, electric motors will be lighter. If you need a modest amount of power, then gasoline can still win since the fuel tank is so light.
Old 09-29-2020, 09:31 AM   #137
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I think you meant "in parallel" based on the pictures?
Spuds is online now   Reply With Quote
Old 09-29-2020, 10:28 AM   #138
Spuds
The Dictater
Spuds's Avatar
Found this more related to Australian efforts, but it helps with background info. I think SA is just capturing the carbon from the traditional method of production.
https://www.sciencemag.org/news/2018...without-carbon
The Following User Says Thank You to Spuds For This Useful Post:
Old 09-29-2020, 10:32 AM   #139
Irace86.2.0
Why is that?
Old 09-29-2020, 10:53 AM   #140
Irace86.2.0
All the exhaust of the 3 cylinders via 3 exhaust valves is going to one turbo at low rpms then all the exhaust via 6 exhaust valves goes to both turbos at high rpms. This is one of the benefits of Freevalve, which is the ultimate control of the system without the need for butterfly valves or other complicated actuators.
https://www.koenigsegg.com/gemera/ti...-giant-engine/
Quite simply, one turbo is connected to three exhaust valves – one from each cylinder. The second turbo is connected to the other three exhaust valves. During low rpm and part to high load, all exhaust gasses are pushed to only one turbo, by only opening one exhaust valve per cylinder – thereby doubling the exhaust gases to that turbine. When adequate boost is reached, the second exhaust valve is opened to start the second turbo.
Spuds (09-29-2020)
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 02:46 AM
Does anyone know why pansontw got banned? Soloside Off-Topic Lounge [WARNING: NO POLITICS] 17 10-26-2018 05:20 AM
Got banned from gf's complex jdmblood Other Vehicles & General Automotive Discussions 11 07-12-2015 01:46 PM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 03:23 PM
Banned Toyota GT 86 Advert Banned Nevermore FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 11-16-2012 08:27 PM
