Old 09-10-2021, 01:47 PM   #113
Ultramaroon
fabulous
Ultramaroon's Avatar
I still think it is a geometry issue combined with the valve on the looser side of tolerance. Mine kicked out at about 6k rpm. No valve float. I was actually lifting off when it did it.
+1
blsfrs (09-10-2021), NoHaveMSG (09-10-2021)
Old 09-10-2021, 02:50 PM   #114
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by gonzalezea1996 View Post
I just purchased GSC Beehive springs, valves, and seals. I'm Looking for someone in Virginia with experience to do the work for me, but I don't know where to go. If you don't mind me asking, who was your builder? I have a stage 2 IAG block ready for the heads. The only thing I'm missing is the valvetrain components I mentioned above.
I'm still debating on getting the retainers, so I may wait a little longer to see what's the verdict.
Perfect Circle Engines. Cody Dawson. He's in Bunker Hill WVa. That's just a few miles north of Winchester. He's popular and has a long wait list.
Old 09-10-2021, 03:12 PM   #115
blsfrs
blsfrs's Avatar
Probably more of a geometry problem than lash. I've heard the "updates" includes longer valve stems and a change in rocker arms and possibly a wider cam surface. The lash should decrease with wear due to valve recession so, in theory, should be less of a factor in an older engine .
I did see a You Tube video where deposits on the valve stem caused valve float in a street driven Corolla. I wouldn't think that's likely on a track driven engine.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 09-11-2021, 12:05 AM   #116
makinen
makinen's Avatar
Drives: Toyota 86
Even it could occur under 3k rpm. That was my case.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
HKS GT EL header, 17MY intake manifold */
makinen is offline   Reply With Quote
The Following 3 Users Say Thank You to makinen For This Useful Post:
blsfrs (09-11-2021), NoHaveMSG (09-11-2021), rixter145 (09-11-2021)
Old 11-06-2021, 09:13 PM   #117
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Valve float is caused by a few things. Spring harmonics or spring resonate frequencies are the main reasons. Its basically springs that are very well controlled, no fault of the valve or rpms. Its just physics. The beehive spring addresses this problem better than any other solution as far as I know. Here is a good video on spring technology. If its too long for you, skip to about 20 minutes to see the springs in action. But watching the entire video explains a alot
Rabrooks is offline   Reply With Quote
The Following User Says Thank You to Rabrooks For This Useful Post:
Ultramaroon (11-06-2021)
Search this Thread:
Advanced Search
Trans retainer cover Jcas Engine, Exhaust, Transmission 0 04-29-2019 05:24 PM
WTB: spare wheel retainer screw Pat Want-To-Buy Requests 4 04-06-2016 01:57 PM
Pop-Screw Retainer Size? FR-S Matt Scion FR-S / Toyota 86 GT86 General Forum 2 01-20-2013 11:48 AM
big black plastic retainer poormans_LFA BRZ First-Gen (2012+) -- General Topics 66 02-11-2012 03:33 AM
