Old 09-01-2020, 01:36 PM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by captain awesome View Post
Tires. I don't have much life left in the Re71s. People say they go all the way down to the cords, but I've never really ran tires below the wear bars before. I need to research how much I really have left, but they only have 4 track days and 1 autocross.
If you replace RE71R when wear gets to the indicators, you're getting less than half the useful life out of them. I would also be at the indicators after 4 track days, but when I kept running them on the BRZ while Porsche was in the shop last year, I got 6 more track days out of them and didn't reach the cords or lose much if anything in terms of grip due to heat cycles.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
captain awesome (09-01-2020), strat61caster (09-01-2020)
Old 09-01-2020, 01:42 PM   #30
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'll snap some pics later, but my rear tread is almost gone. The fronts have a fraction more, so if I swapped to the rear I have maybe another half day on them. UNLESS you can run them with zero tread depth left.
captain awesome is offline   Reply With Quote
Old 09-01-2020, 01:51 PM   #31
captain awesome
Wears Pants
Originally Posted by M0nk3y View Post
Via a friend hookup. Nice to get to know people
JB Racing Tires is a good spot to check out though.
My current set has 21 HCs on them. Just ran 6 sessions (20 minute stint hot laps) on them at NCM last event and they're starting to fall off now. Pace wise they're about a Yokohama Pace
I've had a couple friends order autocross compounds through JB and seemed to be pleased. I'll ask around to see if there's any that pop up. I know I can get some 255 40 17 Gforce 1s for cheap, but not sure those are worth snatching up over spending a little more for the r7s.
Old 09-01-2020, 01:59 PM   #32
strat61caster
strat61caster's Avatar
I'd say this is the replacement mark;
We've run them down to this;
They get edgier, much harder to get 10/10ths out of them, but they still feel like they have grip to my butt dyno.
ineedyourdiddly
Old 09-01-2020, 02:02 PM   #33
captain awesome
Wears Pants
My rears are right about the same as yours above except my shoulders are even. Fronts have a smidge more depth, but I'll double check this evening.
Old 09-01-2020, 02:09 PM   #34
ZDan
ZDan's Avatar
Drives: '23 BRZ
You can run them with zero tread depth left...
Old 09-01-2020, 02:09 PM   #35
strat61caster
If you were autoxing I'd say another event day or two depending on conditions via swapping, but assuming your TT offers HPDE levels of seat time (1-2 hours per day) fresh tires are relatively cheap.
ineedyourdiddly
Old 09-01-2020, 02:11 PM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
You need more camber!
You probably should have flipped them before it came to this...
On my BRZ with -3.3 front -2.6 rear camber I never flipped them, just rotated every event. I ran them as "slicks" for at least 3 track days. Never showed cord.
ML (11-29-2020)
Old 09-01-2020, 02:40 PM   #37
captain awesome
Wears Pants
Has anyone run the Falken rt660 yet?
Old 09-01-2020, 04:02 PM   #38
strat61caster
I'm not honestly sure where I was at for that set of tires, I'm on -4.3°F and -2.3°R right now, will probably bump the rear up a bit and reduce the front a touch since I'm getting some inner camber wear along and I'll try a bit of toe out.
ineedyourdiddly
Old 09-01-2020, 04:45 PM   #39
DarkSunrise
DarkSunrise's Avatar
Interestingly I ran my rear tires like that at my last track day but with inner camber wear instead of outer. The tires (RS3's) felt the exact opposite. Loose but easy to catch in corners. Never felt like they had any real grip especially on throttle.
2022 BRZ Build
2013 FR-S Build
Old 09-01-2020, 05:12 PM   #40
strat61caster
Different rubbers and construction, not surprising they act different as they age.
I hear BFG's for example feel exactly the same, they just have less grip.
ineedyourdiddly
DarkSunrise (09-01-2020)
Old 09-01-2020, 05:21 PM   #41
DarkSunrise
Yeah good point. I wouldn't be surprised if it had more to do with construction/compound vs. wear pattern.
Is the consensus basically that tread depth has zero correlation to dry grip?
2022 BRZ Build
2013 FR-S Build
Old 09-01-2020, 05:34 PM   #42
strat61caster
Depends on the tire, some have layered compounds and along with the age/heat cycle changes of the compound you may hit a point where you've used up all the sticky stuff before the grooves are gone.
ineedyourdiddly
Search this Thread:
Advanced Search
Delicious Tuning - NA Development Thread DeliciousTuning Engine, Exhaust, Transmission 75 06-14-2020 03:32 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 05:12 PM
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox FT-86 SpeedFactory Engine, Exhaust, Transmission 733 12-11-2018 11:13 PM
Raceseng | Development FT86 | Build Thread Raceseng Member's Car Journals 17 06-06-2013 10:22 AM
