Old 07-30-2020, 12:44 PM   #15
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by daniloneil8 View Post
I am only referring to OEM studs, not extenders.
In that case, rear OEM stud is same as front?
Just pound out and pull in, and just need to find that gap?
Nothing special about the rear?
I used this to get the OEM studs out, I broke 4 of them and had to replace them:
https://www.harborfreight.com/3-4-qu...tor-99849.html
Also used it to push the piston back in when putting in new brake pads.
Clueless
YamahaR86 is offline   Reply With Quote
Old 07-31-2020, 11:27 AM   #16
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by RToyo86 View Post
I just installed 2.5" ARP and did not remove the rear hub.
The nipples on the end are the only thing stopping them from going in.
So what did you do to get them on without removing the hub? Grind off the nipple?
CrowsFeast is offline   Reply With Quote
Old 07-31-2020, 11:55 AM   #17
Joveen
Joveen's Avatar
Drives: Bone stock
Just a hammer and knock em out. Lol.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 07-31-2020, 12:04 PM   #18
CrowsFeast
CrowsFeast's Avatar
You should really read before you post.
RToyo86 stated that the nipple was stopping him from installing the extended studs in the rear without removing the hub, but that he also accomplished it without removing the rear hub. As I have extended studs to install I'd like to know how he did that as I'd rather not have to remove the hub/undo the axle nut if I don't have to.
Old 07-31-2020, 01:00 PM   #19
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Yes.
I cut them off with a Dremel, then wiggled them in.
Search this Thread:
Advanced Search
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 11:50 AM
FS: 20 OEM Wheel Studs (new) skylinekin Brakes, Suspension, Chassis 1 02-24-2020 10:33 PM
Want to install ARP wheel studs in front...any recommendations? VVT4ME Northwest 3 05-25-2017 03:36 AM
Stoptech Front 328x28 - Minimum spacer size with OEM wheels ? asnatlas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-14-2017 12:38 AM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
