| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 BRZ Sport-Tech
Mods that you instantly regretted?
Recently installed the Whiteline and Perrin transmission mount reinforcements (had to drill out the Whiteline hole to fit the Perrin). With all the rusted bolts and not having my regular jack (had a short one so that by the time it was on jack stands I didn't have much room under the car) it was a real PITA to get the mount out.
I was relieved when everything was done until I went to back out of the garage. The increased vibrations when you're just starting to engage the clutch are huge! There's such a difference that I'm finding I'm not giving it quite as much gas as I usually do, which in turn makes it start to bog, which makes it worse. Now I could adapt to that and it would be ok but then I went for a test drive... omg the gear whine... I upgraded the transmission mounts in both my previous cars and never experienced anything like this. Hell, in my first car I upgraded the trans mount, cammed it and wound up with a steering wheel that bounced like a damn drag car if the AC was on when idling and it wasn't anything like this! The car sounds great when doing a pull but it's a bit absurd for just driving around town. I'm leaving them both in for now hoping it will get better as things settle/break in but I may wind up removing one or the other in a month or 2. Kind of feel like I've ruined it for now though. On the plus side my shifts feel great especially since I installed a kartboy shift bushing at the same time! (had to boil the bushing to get it to slip over the pin and look up some guides online to find out about dropping the drive shaft support for space but it went ok overall) |
| The Following User Says Thank You to CrowsFeast For This Useful Post: | HaXx (07-06-2020) |
Drives: Bone stock
I was in the same boat months ago minus the whole cutting part. The sound the car made on first start up made me think mess up my car haha. Then hearing the flywheel drove me crazy for a while. It's been 4 months since install and barely even notice it there. I sometimes forget I installed them. I think they have finally settled in but I still hear the flywheel noise (transmission noises rather) every now and again. If I had to do it again I would just go with the sti transmission mount because it replaces those 2 things used. I would go STI trans mount and perrin shifter bushing along with STI or torque solution engine mounts.
Sent from my SM-N960U using Tapatalk |
| The Following User Says Thank You to Joveen For This Useful Post: | MJones_RB (07-06-2020) |
#3 | |
Drives: '13 BRZ Limited
Huge increase in NVH with no real benefit to shifting. Not at all worth it IMO. I regret spending the $100. I would not swap any of these bushings, esp the shift lever retainers. It was kind of a fun experiment, but the end result was worse than stock for me even with it being mostly a weekend/track toy. |
Rust bucket enthusiast
Heavy wheels. Bought XXR 18x8.75 wheels, car was much slower at low RPM and taking off from a dead stop. Swapped on my 16x7 winter wheels and tires just to have the driving enjoyment back
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Dzmitry (07-07-2020) |
Drives: Crapcan
Solid subframe mounts. They are a little much on a car that sees very much street driving.
Aluminum one piece drive shaft. Will not balance, terrible vibration.
Just the tip
Drives: 2017 DGM BRZ
IRP v3 short shifter.
Shifting was fun, but even with the "fixed" version of the shifter it had unbearable rattle starting at 2500 rpm all the way up to redline. Definitely not acceptable to me for a daily so I removed it a week later and sold it. |
#7 | |
Drives: 2018 BRZ
Painting brake calipers - not on the BRZ, but I was all excited getting the calipers painted, but once done I didn't like the result at all. I know, a cosmetic mod, but one that takes quite some time to do and is hard to undo. I'll stick to unpainted or painted silver/black in the future.
| The Following 14 Users Say Thank You to Tcoat For This Useful Post: | brandonblt2 (07-08-2020), Compelica (07-08-2020), DarkPira7e (07-07-2020), Dzmitry (07-07-2020), Joveen (07-06-2020), Kiske (07-06-2020), KR-S (07-07-2020), NoHaveMSG (07-06-2020), RToyo86 (07-06-2020), Sapphireho (07-06-2020), soundman98 (07-06-2020), Spuds (07-06-2020), weederr33 (07-06-2020), wolffbite (07-06-2020) |
TRD's Short Shifter Kit. This thing did nothing but cause problems for me. The bolt kept coming loose to the point that I could barely get it into gear. No amount of Lock Tite would help. PLUS I had to tear the rubber boot to get it off. When I finally de-installed it I smashed that damn thing with a hammer for all the trouble it caused me.
Some people install it and have no issues. Not sure what I did wrong but that one really got me. |
#10 | |
Famous Potatoes
Drives: '15 ultramarine
| The Following User Says Thank You to Sapphireho For This Useful Post: | MJones_RB (07-06-2020) |
#11 |
Drives: Bone stock
#12 |
Drives: 2020 Subaru BRZ TS
Anyone regretting going forced induction and ending up with a ton of issues? Curious about this too.
#14 | |
Drives: 6MT '15 BRZ | '89 240sx (sold...)
The main reason why I avoided 18" (aside from tire costs) and bought real SSRs even though reps would have mostly worked fine for daily driving and the occasional track day.
la cocaina is not good for you ig: sad_fa20 |
| The Following User Says Thank You to sukumizu For This Useful Post: | DarkPira7e (07-07-2020) |
| Who has upgraded... and regretted? | bfrank1972 | FR-S / BRZ vs.... | 104 | 04-11-2019 07:00 PM |
| What mods have you done so far? | Rossi | AFRICA | 148 | 11-16-2015 02:41 AM |
| more mods on the way! | Frsultramarine15 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 04-11-2015 05:35 PM |
| July 10th 2013 new fuel pump same noise instantly | dhenson405 | Issues | Warranty | Recalls / TSB | 59 | 07-16-2013 04:27 PM |
| Mods vs possible BRZ STI | Coaster | Engine, Exhaust, Transmission | 59 | 07-13-2012 12:19 AM |
