| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ
Crawford Performance Billet Power Blocks
Hello,
So I installed the power blocks last summer and at first they were causing my engine to shut off. Turned out, when I was installing, one of the gaskets ripped and when the engine created the vacuum, the gasket completely tore. I replaced all gaskets, even the manifold ones, but a new problem appeared. Every so often the RPMs dip when I idle in neutral and it sounds like the engine is going to cutoff. And sometimes in the middle of driving the engine does cutoff. I contacted CP about this and they told me no one else has reported this problem with the blocks. They also said to check the gaskets and make sure they're seated properly and to check the ground extension. I did those and they're both fine. So now I'm back to my original theory that it's a tuning thing. Did anyone else have this problem? If so, what did you do to fix it? Also, am I correct that it is a tuning thing? Any help would be greatly appreciated... |
friendly
Drives: 17' 86
I would guess you need a tune. Any CELs?
Seek comfort in discomfort.
Yes there is, but I'm pretty sure its from the UEL header. I had a recall on my car and when they pulled the engine to replace the part, that's when the CEL came back on.
Drives: JRSC BRZ SOLD
You need a tune to take advantage of the BPB and headers. Additional it would get rid of the CEL.
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | alphasaur (07-02-2020) |
Drives: RX-7 / BRZ
May be worth undoing the battery and letting the car relearn after driving with a vac leak. Also, a tune done only once the parts are correctly installed. Unless the UEL and PB aren't playing nicely it still sounds like you have to recheck your install.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
Make sure the ground to your ECU is connected completely. That's where most of the problems come from. The ECU loses it's ground loop and shuts the engine off.
| The Following User Says Thank You to MJones_RB For This Useful Post: | Lantanafrs2 (07-02-2020) |
Drives: 2013 frs red
13s had idle issues with stock tune
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
Still sounds like a vacuum leak. My mechanic cleaned the manifold areas before installing the brand new gaskets. He said any dirt can create a space in between the gasket & the manifold & create vacuum leaks. It took us a while of moving the manifolds a little to set it in place & seal the gaskets properly.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
| New Crawford Performance Billet Power Blocks | ANUSTART | Engine, Exhaust, Bolt-Ons | 3 | 10-15-2019 12:34 PM |
| How to install Crawford Performance Billet Power Blocks (video?) | Mr. | DIY (Do-It-Yourself) Guides | 51 | 09-08-2019 07:10 PM |
| WTB: Crawford Performance Billet Power Blocks | DR 86 | Canada Classifieds | 7 | 05-11-2016 01:15 PM |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
| FS: Crawford Billet Power Blocks | FRSH86 | Engine, Exhaust, Bolt-Ons | 17 | 09-21-2015 03:52 PM |
