Old 07-02-2020, 02:51 PM   #15
strat61caster
strat61caster's Avatar
How many track days/sessions on the tires? Most tires lose grip after 10-12 heat cycles even though they have plenty of tread left.
ineedyourdiddly
Old 07-03-2020, 10:01 PM   #16
wparsons
wparsons's Avatar
I'd swap the tires front/rear and see if it follows the tires. Was it noticeably worse one side more than the other?
flickr
Old 07-04-2020, 01:53 AM   #17
mamamiaellis
Drives: brz
The tires has 2 track days.
I tried rotating the tires. Still same issue. Both left and right turns.
mamamiaellis is offline   Reply With Quote
The Following User Says Thank You to mamamiaellis For This Useful Post:
strat61caster (07-04-2020)
Old 07-07-2020, 10:23 AM   #18
steverife
Drives: 2016 Scion FRS
Have you checked for sway bar bind?
steverife is offline   Reply With Quote
Old 07-14-2020, 03:03 PM   #19
mamamiaellis
Drives: brz
Hey steverife,
Not sure what swaybar bind is.
But small update.
Turns out my rear endlinks are totally shot.
The rear lca bushing was shot and the bushing in the knuckle, i can move with my finger. ( theres resistance, but i can still move it.)
Im assuming these are the reasons for my unpredicranle handling.
Has anyone replaced the bushing in the rear knuckle before?
Old 07-14-2020, 03:17 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hydraulic press is your good friend here.
Old 07-14-2020, 06:42 PM   #21
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Well you're obviously losing rear grip. Snapping on exit or is it starting to come undone just after mid corner?? Are you on throttle or still off after the apex?
It sounds like a tire pressure issue combined with a small technique issue?
Old 07-15-2020, 05:57 PM   #22
mamamiaellis
Drives: brz
Its coming undone just after the apex.
I am definitely not the most adept driver. Always learning.
But it never felt like thisbefore. Even the slightest bit of gas would cause massive oversteer. Im not the most aggressive driver so it's just strange to me this happened suddenly lol.
I checked my car out. Both boots on my rear endlinks were completely open and oozing grease. Both lca and rear knuckle bushing i can move. The knuckle bushing is more resistant, but if i try hard enough, i can move them with my fingers.
I assume this was the issue. Ha d a shop BRIEFLY inspect my car. No frame damage lol.
I replaced alot of parts. Will prob get it aligned this weekend or next and see if it's any better..
Thanks for everyone's help
Old 07-15-2020, 06:24 PM   #23
Come out to the next 86cup day and i can evaluate the car for you.
Old 07-15-2020, 10:22 PM   #24
strat61caster
They're supposed to move in some directions, but not others so hopefully you aren't tearing it apart for nothing.
ineedyourdiddly
Old 07-20-2020, 02:59 PM   #25
mamamiaellis
Drives: brz
Thanks mike for the offer. I might take you up on that in the future.
But i have all of my parts in. And i got it realigned.
While i was at it, i decided to upgrade my outer front tie rod for funzies.
But the bumpsteer is dangerously close to the wheel. Anyone know od solutions to clearance issues for outer tie rods?
My alignment guy says unfortunately rn, its the best he could do. Says theyre like thay by design.
They are very close. Maybe 2-3mm?
Thanks
Search this Thread:
Advanced Search
Snap Oversteer's Varis Arising II Seat Time Build Wangaroo Member's Car Journals 3 04-17-2019 06:22 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 10:24 PM
Oversteer during overtaking Roarke BRZ First-Gen (2012+) -- General Topics 20 10-08-2014 07:20 AM
Controlling Oversteer? Neokolzia BRZ First-Gen (2012+) -- General Topics 29 09-22-2014 11:58 PM
frs oversteer in brz mechanical? swpbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-18-2014 10:48 PM
