Old 10-05-2022, 03:07 PM   #15
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by Swisher Seattle View Post
HKS HIPERMAX S is the best ever for 86
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
finch1750 (10-05-2022), MyHybridBurnsGasAndTires (10-05-2022)
Old 10-05-2022, 03:14 PM   #16
strat61caster
strat61caster's Avatar
Originally Posted by RToyo86 View Post
Lol
ineedyourdiddly
Old 10-05-2022, 06:25 PM   #17
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
RCE SS1. All the travel, great ride quality and solid build. Sold my MCS 1WNR for these and couldn't be happier.
Lincoln Logs is offline   Reply With Quote
The Following User Says Thank You to Lincoln Logs For This Useful Post:
Racecomp Engineering (10-05-2022)
Old 10-06-2022, 09:56 AM   #18
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Watch out, we got an expert over here!
Old 10-07-2022, 10:13 AM   #19
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I've listened to enough podcasts and done enough research to know RCE really knows their stuff. I haven't met anyone or read online of anyone who's disliked their SuperStreet-1 or Tarmac 2 options. The SS-1 will come in right at your $2k budget with a little buffer room for some other things you'll need like alignment and possibly even rear lower control arms for more adjustability.
For my STX autox build, I'm very likely going with one of the two, depending on how much money I want to dump into it. I also like both options are very streetable too.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Racecomp Engineering (10-07-2022)
Old 10-07-2022, 11:32 AM   #20
dreamwonder
Drives: GR86 2022
Originally Posted by ZDan View Post
For OP usage, coilovers are not strictly necessary.
I recently went to Bilstein B8s (B6s would also work) with Swift Spec R springs. Pretty great on the street, quite a bit stiffer than stock at 4.4 kg/mm front, 5.3 kg/mm rear, car is ~1.25" lower than stock. I'm also running Raceseng camber plates, which I had to have 6mm spring spacers machined for the fronts to prevent the front from being too low. Not necessary if you run factory strut isolators, or perhaps other camber plates...
Anyway this was a tremendous improvement for me vs. previous setup with Swift BRZ Sport springs with stock PP Sachs dampers and Raceseng plates. That setup had about zero bump travel up front Actually worked OK at the track but on the street it was murder... The Bilsteins have WAY more bump travel
Speaking of bumpstops...I been using budget tires for a number of years (as you know, I do lots of days) but got a set of the good stuff recently...finally...lol!
For the first time (on JRZs RS1, 450lb squared, 21mm front bar, 20mm drop), I felt the car bottoming out. Upon inspection, the bumpstop actually ate the coilover seals
Staying on topic...my vote goes to RCE SuperStreets as well, or one of the KW variants. I like there general build quality, they can stay on the car all year round and the front plates is the best I have used.
dreamwonder is offline   Reply With Quote
Search this Thread:
Advanced Search
recommendation suspension alignment bridgetown1 Mid-Atlantic 2 01-20-2020 10:27 PM
Supercharger mark up dtrop Forced Induction 8 08-13-2015 03:37 PM
Poor 86 at 2:50 Mark Jason@DSG Scion FR-S / Toyota 86 GT86 General Forum 18 11-18-2014 02:04 PM
Nav - how to mark blockage? MysteryMachine Electronics | Audio | NAV | Infotainment 0 12-23-2013 06:59 PM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 02:41 PM
