86WORX
Old 04-25-2023, 05:00 PM   #435
1st86 Driver!
Yeah, I think it is presumed crashed. I only heard about it today so wasn't sure what they would be streaming. Real time video is actually hard to send long distances, I'm sure they had a camera running to transmit compressed later.
agree on the video, but still disappointing.
What would suck even more is if it landed perfectly but the comms are broken. If I was the "owner" I think I'd rather have a fireball!
The photo they showed in the "preshow" with the Moon shadow on the Earth during an eclipse was pretty cool. I'd buy a poster of that.
Capt Spaulding (04-25-2023), Spuds (04-25-2023)
Old 08-23-2023, 10:38 AM   #436
1st86 Driver!
Congratulations to India for a successful soft landing near the Moon south pole!
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
bcj (08-23-2023), Irace86.2.0 (08-24-2023), pope (08-23-2023), Spuds (08-23-2023), Ultramaroon (08-23-2023)
Old 08-23-2023, 09:46 PM   #437
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
And congratulations to the Russians on making another crater in it!
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Dadhawk (08-24-2023), Irace86.2.0 (08-24-2023)
Old 08-24-2023, 12:02 AM   #438
Unplugem
Drives: GR86 (Sold) -> C6 GS Edelbrock SCed
Dang, you actually believe that junk? It's all Jesuit theater. None of it is real; they have you living in augmented reality. I guess it's all that "spinning at 1,000 mph" and all... I'd probably believe anything I was told too, if I was spun around that fast. It must be torture to be exposed to those speeds and never get a reprieve. You have my sympathy.
Unplugem is offline   Reply With Quote
Old 08-24-2023, 12:17 AM   #439
Unplugem
Can confirm as I saw a few launches when I lived in Florida upclose and at a distance. Even from 200 miles away (I lived in W. Palm Beach) the night shots were spectacular.
The office I worked in in Boca Raton was about the tallest building in the area at 10 stories. I buddy of mine had an office on the 9th floor that faced North. He had a square marked out on his window. At about 20 seconds after launch you could watch the shuttle arc through the window. Obviously couldn't see details but you could see the rocket plume as it climbed.
That doesn't come close to seeing it up close though.
Haha that "arcing" is the overpriced bottle rocket dropping back to the ground. They like to launch them on the coast of Florida. They fall right back down and land in the Atlantic Ocean, the Bermuda Triangle, to be exact. If any poor soul out on a boat sees the overpriced POS fall into the water, then they are disappeared. Now at least you folks know the truth about the mysterious Bermuda Triangle.
Old 08-24-2023, 08:38 AM   #440
1st86 Driver!
Bermuda Triangle is a myth propagated by the Atlanteans who's missile defense system developed and managed by Flipper and Moby ****, is out of control and shoots down everything that passes over.
I know this for a fact because Bruce told me so. It's the message you get when you play the theme from Jaws backwards at 72rpm.
bcj (08-28-2023), Irace86.2.0 (08-24-2023), NoHaveMSG (09-18-2023), Spuds (08-24-2023), Ultramaroon (08-24-2023)
Old 08-24-2023, 01:54 PM   #441
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Spuds (08-24-2023)
Old 08-24-2023, 02:06 PM   #442
Irace86.2.0
Spuds (08-24-2023)
Old 08-24-2023, 06:48 PM   #443
Unplugem
https://www.youtube.com/shorts/pRkOW...?feature=share
You're mocking yourself here pal.
Old 08-24-2023, 08:35 PM   #444
1st86 Driver!
Sure, that's what I was doing. Totally caught me.
Spuds (08-24-2023)
Old 08-24-2023, 09:27 PM   #445
Ultramaroon
fabulous
Ultramaroon's Avatar
Dadhawk (09-18-2023), Spuds (08-24-2023)
Old 08-24-2023, 11:12 PM   #446
Unplugem
You seem to be quite excited about a cartoon animation.
Old 08-25-2023, 03:17 AM   #447
Irace86.2.0
Your ignorance of science is astounding. It makes sense why you fail to protect your mind from conspiracy theories and fall for this type of crap.
You clearly don't know how objects like satellites and the International Space Station (ISS) stay in low Earth orbit (LEO). Objects in LEO are maintaining their altitude above ground by falling with enough tangential velocity to not spiral into Earth or too fast to fly off into space. Their tangential velocity is fast enough to orbit the Earth, and it is why they are moving fast above us and not just sitting in position. If the ISS was just hovering overhead then gravity would pull it down to Earth, but because the ISS is orbiting the earth, it is necessary to fire the rocket in an arching angel to intercept the ISS and to achieve escape velocity.
The escape velocity relative to the surface of a rotating body depends on direction in which the escaping body travels. For example, as the Earth's rotational velocity is 465 m/s at the equator, a rocket launched tangentially from the Earth's equator to the east requires an initial velocity of about 10.735 km/s relative to the moving surface at the point of launch to escape whereas a rocket launched tangentially from the Earth's equator to the west requires an initial velocity of about 11.665 km/s relative to that moving surface. The surface velocity decreases with the cosine of the geographic latitude, so space launch facilities are often located as close to the equator as feasible, e.g. the American Cape Canaveral (latitude 28°28′ N) and the French Guiana Space Centre (latitude 5°14′ N).
If an object attains exactly escape velocity, but is not directed straight away from the planet, then it will follow a curved path or trajectory. Although this trajectory does not form a closed shape, it can be referred to as an orbit. Assuming that gravity is the only significant force in the system, this object's speed at any point in the trajectory will be equal to the escape velocity at that point due to the conservation of energy, its total energy must always be 0, which implies that it always has escape velocity; see the derivation above. The shape of the trajectory will be a parabola whose focus is located at the center of mass of the planet. An actual escape requires a course with a trajectory that does not intersect with the planet, or its atmosphere, since this would cause the object to crash. When moving away from the source, this path is called an escape orbit. Escape orbits are known as C3 = 0 orbits. C3 is the characteristic energy, = −GM/2a, where a is the semi-major axis, which is infinite for parabolic trajectories.
https://en.wikipedia.org/wiki/Escape_velocity
Musk/SpaceX and others are landing rocket/boosters on land and platforms in order to save money on the cost to go to space, so you won't see these boosters landing in the Bermuda Triangle, but NASA ultimately found it to be too expensive to retrieve sunken boosters from the ocean, so those initial stage boosters that broke off of the rockets do land in the ocean. This is by plan, but the rest of the rocket does continue into orbit.
I'm curious, do you think the ISS and satellites circling overhead are holograms or something? Do you think GPS is just voodoo?
Old 08-25-2023, 03:45 AM   #448
Irace86.2.0
Again, more ignorance.
--Dude, they are using an animation mirroring the ship's distance and landing angel relative to the ground looking out at the moon's surface from the POV of the ship, obviously, because the ship can't take a picture of itself landing.
--The reflection is fine. Take a mirror and tilt it back away from you and look down, and you will see down. Shoe stores know this, so they put mirrors on the benches.
--The first image is of Earth from an astronaut standing on the moon looking up. --The second image is known as Earthrise, which is a photograph of Earth and part of the Moon's surface that was taken from lunar orbit by astronaut William Anders on December 24, 1968, during the Apollo 8 mission.
https://en.wikipedia.org/wiki/Earthrise
Dude, this is entertaining, but you gotta stop because you are getting taken to grade school. You can't keep getting pwned like this and just ignoring the hard evidence, and instead of acknowledging things, you resort to, "but what about this?" You gotta look things up for yourself and not take every stupid thing you hear or read at face value. (If you are disabled, autistic or learning impaired in some way, I'm sorry if I'm overly harsh on you with these facts)
Dadhawk (08-25-2023)
Search this Thread:
Advanced Search
Which Space Saver will fit? Andrew666 AUSTRALIA 25 06-18-2020 10:07 AM
Cockpit Space Chad86 Scion FR-S / Toyota 86 GT86 General Forum 7 03-15-2014 04:24 PM
First run 86's (Space Saver question) DriftEightSix AUSTRALIA 11 01-10-2013 08:25 AM
FR-S space saver sierra Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2012 01:18 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 01:29 PM
