Old 02-16-2014, 04:57 PM   #15
diss7
Drives: AE86, 2x GT86, TE27
Originally Posted by MicheleAbbate View Post
did you ever figure this out?
Toyota NZ sell what you need.
Here are the part numbers
SU003-00499
PULLEY ASSY, IDLER
SU003-00515
BRACKET, IDLER PULLEY
Email nick@nst.co.nz
It would be about $300 for everything you need, at a guess.
diss7 is offline   Reply With Quote
The Following 5 Users Say Thank You to diss7 For This Useful Post:
86-tundra (02-16-2014), Akuma-ZN6 (02-26-2019), DAEMANO (02-18-2014), hmong337 (03-13-2015), King Tut (02-18-2014)
Old 02-16-2014, 04:58 PM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I think after 2 years and heaps of track time 000 would have sorted this out by now.
Old 02-16-2014, 05:00 PM   #17
diss7
I don't doubt that.
I was providing the answer for the person that asked about it this morning.
The Following User Says Thank You to diss7 For This Useful Post:
Old 02-18-2014, 03:11 AM   #18
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
SU003-00499
PULLEY ASSY, IDLER
SU003-00515
thanks dude, helpful info
MicheleAbbate is offline   Reply With Quote
Old 03-12-2015, 06:30 PM   #19
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
Drives: 2017 civic type R #1353 2017 ss1le,
Bump. Has any removed ac? And if so did any lights come up on gauge cluster.?
GhostOp86 is offline   Reply With Quote
Old 03-12-2015, 06:31 PM   #20
MicheleAbbate
Yes no lights
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
The Following User Says Thank You to MicheleAbbate For This Useful Post:
GhostOp86 (03-12-2015)
Old 03-12-2015, 09:21 PM   #21
mrk1
Drives: Sterling BRZ Ltd
I have the "AVO" kit, it's actually subaru factory parts.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-13-2015, 03:14 PM   #22
ATL BRZ
Driving Coach
ATL BRZ's Avatar
@Anthony did it with the JDM part: http://www.ft86club.com/forums/showt...97#post2113297
30 lbs of weight loss
Old 03-13-2015, 09:53 PM   #23
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I would recommend this only for a total track-car for competition use where fractions of a second are more important than driver comfort.
I did an A/C delete on my old RallyX car. I completely regretted it. Sitting in the car on hot summer days were killer! I gladly would have given up a fraction here and there for the ability to keep from boiling in my car on a 100 degree day.
And don't even THINK of removing your HVAC system without some sort of replacement. A friend of mine did that to his stripped-out RallyXer. Now he's constantly battling window fogging if it's even a little bit cool out.
Moral of the story: You may be ok with losing some driver comfort, but be sure you're not losing driver function at the same time.
The Following User Says Thank You to Draco-REX For This Useful Post:
ATL BRZ (03-13-2015)
Old 03-22-2015, 08:12 PM   #24
86drift
86drift's Avatar
Drives: Toyota 86 GT
Chris did in fact use the factory parts as per Diss's post:
SU003-00499
PULLEY ASSY, IDLER
SU003-00515
I'm keeping my AC even though it's a race car. Since the AC clutch disengages on full throttle you don't loose any HP. Just a few kg, which I'm happy to trade because I can concentrate better in 25 deg C much better than in 60 deg C.
86drift is offline   Reply With Quote
The Following User Says Thank You to 86drift For This Useful Post:
15limited (07-03-2016)
Old 07-03-2016, 06:52 AM   #25
kingkenny
Drives: 2014 Toyota GT86
I have a question ...Can we just get a shorter belt and by pass the AC pulley ? I done this before in other car, just surprises that even ac delete or non ac model still have a ac pulley .
kingkenny is offline   Reply With Quote
Old 07-03-2016, 07:44 AM   #26
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Non AC model still have an A/C pulley. Here is the OEM part:
The Following User Says Thank You to nikitopo For This Useful Post:
kingkenny (07-03-2016)
Old 07-03-2016, 03:30 PM   #27
kingkenny
Initial thought was ...just find a shorter belt , keeping all the AC parts in place , just figure it out that no point to do that , because there is no way to by pass the ac pulley . Even AC detele , the belt still need to go around it .
Now I have this weird idea come up , if I run a electric water pump ... and find 2 belt to do with and without AC setup
(Auto Factory Japan has a electric water pump kit)
1.belt that go through CDGE without AC
2.belt go through CDGEHF with AC
Does it work ? Any issue ? Rough idle ?
Old 07-03-2016, 11:26 PM   #28
15limited
15limited's Avatar
Raceseng makes a pretty expensive AC delete pulley.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
