Old 05-03-2020, 12:13 AM   #113
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
Originally Posted by BirdTRD View Post
Doh! Time to spill a little fuel then I guess.
As far as the intake gaskets and mating surfaces, I think that junk you see is just dirt and grime from all the stuff you sprayed around leak hunting.
Did you say you checked your MAF o-ring and it was good?
Makes sense about the grime.
Yeah, over if the smoke tests I did was partially looking for the MAF to leak. It's snug as a bug.
The veins in the MAF don't look lines up perfectly, could that few degrees maybe cause issues? Grabbing at straws here
snowtaipan is offline   Reply With Quote
Old 05-03-2020, 12:15 AM   #114
snowtaipan
snowtaipan's Avatar
Just have a rag over the bolt. Undo it slowly like a shaken can of soda. It isn’t bad.
Well, time to donate another t shit to the car lol
Old 05-03-2020, 12:18 AM   #115
snowtaipan
snowtaipan's Avatar
Might as well check the direct injectors n seals.
IDK, those didn't get pulled during install so there shouldn't be any issues, but opening it up could create some.
Old 05-03-2020, 12:29 AM   #116
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
If it were me...I'd put it back to stock and test the shit out of it and verify all sensors and readings are where they should be and there are no issues that snuck in.
If you rule out hardware and installer-err, the only thing left if software.
BirdTRD is offline   Reply With Quote
Old 05-03-2020, 01:45 AM   #117
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Except the P117B and the addition of considerable more cylinder pressure and heat.
https://www.cardiag.me/obd2-en/p117b-toyota/
https://www.google.com/amp/s/amp.red...ector_failure/
Old 05-03-2020, 01:56 AM   #118
tomm.brz
Drives: brz 2017 hksv2
Do not pull direct injectors out unless you have 4 spare orings and the needed tool to install them
also blown DI orings make a distinctive sound (when you suddenly blip it makes a sound in your engine bay like if you are trying to unblock a sink with a plunger
Make sure MAF is clean
I do not see anything wrong with the High pressure fuel pump
if you had problems with the high pressure fuel pump, it wouldnt even crank, car uses PI during crank but for a briefly moment, it blasts shortly with the DI to keep it running before switching again to PI
i still think is a bad tune, i m helping snowtaipan with this let s see what the next logs will show
Old 05-03-2020, 02:10 AM   #119
Irace86.2.0
What’s the direct injector code about? Could the injector fail on its own? I heard that injector seals can fail then the injector can fail from overheating or something.
Old 05-03-2020, 02:16 AM   #120
Ultramaroon
fabulous
Ultramaroon's Avatar
Blown DI seals make an unholy racket. They are quite obvious.
tomm.brz (05-03-2020)
Old 05-03-2020, 02:31 AM   #121
tomm.brz
it s not like the injectors have sensors. that senses if the oring snap or something like that .. that code is probably causes by the high ltft at low loads
The Following User Says Thank You to tomm.brz For This Useful Post:
Irace86.2.0 (05-03-2020)
Old 05-03-2020, 02:34 AM   #122
Irace86.2.0
But it only effects the direct injectors because the ports aren’t on/dominant?
Old 05-03-2020, 02:37 AM   #123
tomm.brz
that I don t know, it could be.
there are conditions that must be met to trigger those CEL and i dont know them
CEL/DTC are infamous, specially if they trigger indirectly like in this case
Old 05-03-2020, 02:58 AM   #124
Irace86.2.0
I was advised by Zach when he was at DT that my DI seals could be going out based on my logs, so I replaced them. No codes though. No racket, yet no missing or torn seals either, so that may be expected. They just had the usual buildup of carbon, and there was carbon buildup on the tips that I cleaned off. Pics in my build.
Just figured there could be grades of failure from poor sealing to missing seals.
Old 05-03-2020, 03:07 AM   #125
Irace86.2.0
That’s the thing. An intermittent code either immediately goes away if the problem is corrected, or it goes away after a drive cycle. A serious CEL usually comes on with the red warning lamp. A cleared code that doesn’t return when the car starts is a soft code, but it will return if the issue arises again or if the engine goes through the full drive cycle, but didn’t meet the standards.
His issue sounds like a soft code. I don’t know if the problem returns when he just idles it for a while or only if he gets on power or rarer, but if it doesn’t return immediately when the car starts then he should be able to capture the moment the CEL comes on when doing a log then you could assess what the conditions were exactly like at that moment.
Old 05-03-2020, 03:10 AM   #126
tomm.brz
i guess he gets it just sometimes randomly during drive but would need more info from OP about it
edelbrock, p0171, p117b, supercharger
P015A, P015B, P0171, P117B and P0170. kev0 Issues | Warranty | Recalls / TSB 5 08-21-2019 02:30 PM
too lean issue? p117B p0171 engine codes zackegle Issues | Warranty | Recalls / TSB 1 03-21-2017 09:03 PM
P1170 P117B Direct Injection Issue? gonzo Issues | Warranty | Recalls / TSB 4 01-11-2017 03:23 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 03:50 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 05:23 PM
