#85 |
Comparing DI to PI use and trims indicate electric fuel pump is fine.
| The Following User Says Thank You to CSG Mike For This Useful Post: | tomm.brz (04-29-2020) |
#86 |
Drives: '17 BRZ Series Yellow Edelbrock SC
#87 | |
Also that fuel line is a pain in the ass to remove and even worse to reinstall. |
| The Following User Says Thank You to snowtaipan For This Useful Post: | CSG Mike (04-30-2020) |
#88 | |
I'm really starting to lean this way. I know for a fact my idle was at 850-900 before install. It's also developed what I hope is an annoying noise (3 kinds of noise a car makes: annoying, expensive, and the kind where you light it on fire and collect insurance.) I put a stethoscope on it and it's 100% conferring from the TB, and it's new. |
#89 |
I'm really hoping Edelbrock can figure this out, not just for me but do the next guy doesn't have issues.
#90 | |
Drives: Q5 + BRZ + M796
#91 | |
This car isn't being very appreciative... Dropped $5k on a really well reputed supercharger and she's just fighting it! |
#92 |
You removed the harness from the throttle body position sensor, and it stopped making the sound?
#93 |
#94 |
Try removing the harness from the throttle actuator/position sensor then try turning to the on-position. If the noise goes away then it is likely not anything mechanical/electrical with the throttle body, right?
#95 |
Drives: brz 2017 hksv2
boys.... that noise is super normal with ignition ON
you becoming paranoic with leaks and problems that don t exist! |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Irace86.2.0 (04-30-2020) |
#96 |
#97 |
fabulous
It's normal. Yours is actually super quiet. I thought by now that you guys would be working on dbw stuff. No?
#98 |
I couldn't remember off hand, and I can't recall the last time I listened to the engine bay without the car running, but in the on-position. Even then, my electric water pump might be louder.
| Tags |
| edelbrock, p0171, p117b, supercharger |
| P015A, P015B, P0171, P117B and P0170. | kev0 | Issues | Warranty | Recalls / TSB | 5 | 08-21-2019 02:30 PM |
| too lean issue? p117B p0171 engine codes | zackegle | Issues | Warranty | Recalls / TSB | 1 | 03-21-2017 09:03 PM |
| P1170 P117B Direct Injection Issue? | gonzo | Issues | Warranty | Recalls / TSB | 4 | 01-11-2017 03:23 PM |
| Oft Tune E85 Showing Codes P1170 P117B | gonzo | Software Tuning | 30 | 09-05-2015 03:50 PM |
| Engine Code: P0172 P117B | *KID* | Engine, Exhaust, Transmission | 2 | 01-25-2013 05:23 PM |
