#141 |
Drives: brz 2017 hksv2
i m no shocked at all
it takes time to know the ECUs in detail and this car got a major change in tune logic since 2016 and they probably used the time to tune a older one and copypaste everything with small insufficient changes when i get a bit of time i ll send you a correct one, i raised too much the maf scaling and now they are too negative |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | snowtaipan (05-10-2020), Ultramaroon (05-10-2020) |
#142 |
Drives: 2013 FR-S Series 10
Wow, kudos to Tomm
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#143 | |||||
Drives: Q5 + BRZ + M796
#144 |
more than the altitude, the ONLY problem is just really the maf scaling, not appropriated in this case for his 2017 K00C car.
it was scaled too low at low voltage i think the untouched tune could work perfectly in a pre restyling car, where the Engine load compensation is not zeroed at idle manifold pressure values, and would help with keeping engine load a bit higher and possibly not triggering a huge positive ltft to compensate the bandaid was just rise maf scaling values around Idle voltage values Nothing to do with CARB actually? the atmospheric compensation is kept stock, and is kept stock in basically every tune, no one messes with that it just contributed, in this very case, to trigger a DTC because the engine load and maf g/s values were already too low my opinion is they should do like Cosworth you buy a canned tune for Edelbrock? ok, you make a log and Edelbrock SHOULD provide some releases to fix some things to suit the car better They sell ecutek so they are considered "Master tuners", they should act as such Canned tune will always suck if you don t put some work in them to match the final car How many people here had problems with ots tunes, despite it s always the same, even same calibratikn because they hack everything to stable euro tunes And remember that maf scaling changes to some degrees for every single car in the world... sometimes some cars differ a bit more and here we are talking about non-oem applications.. so sometimes you get this |
| The Following 4 Users Say Thank You to tomm.brz For This Useful Post: |
#145 |
Can they make custom tunes to individual cars with these revisions like you say when that would be modifying the CARB tune?
#146 |
why not?
a small adjustment at the maf scaling, what can happen? who notice? at least you make the tune actually perform the way it should, you don t touch targets or anything else if it struggles to keep stoich because someone wrote bad numbers in a couple of cells... I wouldnt think it helps with emission check |
#147 | |
fabulous
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#148 | |
That said, Edelbrock typically develops calibrations on an engine dyno, not a chassis dyno. All the folks I worked with are no longer there, and I don't have a direct line in. |
#149 | |
Because all new cars get logged via OBD2 during the smogging process. When this data from 17+ cars eventually starts appearing, guess who will notice the change? CARB. California™ |
| The Following User Says Thank You to CSG Mike For This Useful Post: | tomm.brz (05-11-2020) |
#150 |
Drives: '17 BRZ Series Yellow Edelbrock SC
I agree, that would definitely pop up as an issue. Since they certify the tune, any variance in the tune would need to get re-certified. And that's not a cakewalk, certainly not something you'd do custom per car.
#151 | |
Exactly, this would get back to CARB 100%, and there would be huge repercussions $$$ or worse.
#152 |
Damn
oh well.. as one who gets passed emission by hooking up the gas sensor to a hidden Fiat running methane next to my car... i'll gently remove myself from this topic :P |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Ultramaroon (05-12-2020) |
#153 | |
| The Following User Says Thank You to snowtaipan For This Useful Post: | CSG Mike (05-12-2020) |
#154 | ||
![]() Quote:
This seems to be demonstrably not the case if scaling the MAF was all that it took to fix the problem, and the tune was responsible for throwing something as serious as CELs. It would either suggest one of several things: that your car is an outlier, that canned/CARB tunes might not be reliable/trusted, or that Edelbrock needs to revisit this tune. It could be more than one of those things.
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | CSG Mike (05-12-2020), Ultramaroon (05-12-2020) |
| Tags |
| edelbrock, p0171, p117b, supercharger |
| P015A, P015B, P0171, P117B and P0170. | kev0 | Issues | Warranty | Recalls / TSB | 5 | 08-21-2019 02:30 PM |
| too lean issue? p117B p0171 engine codes | zackegle | Issues | Warranty | Recalls / TSB | 1 | 03-21-2017 09:03 PM |
| P1170 P117B Direct Injection Issue? | gonzo | Issues | Warranty | Recalls / TSB | 4 | 01-11-2017 03:23 PM |
| Oft Tune E85 Showing Codes P1170 P117B | gonzo | Software Tuning | 30 | 09-05-2015 03:50 PM |
| Engine Code: P0172 P117B | *KID* | Engine, Exhaust, Transmission | 2 | 01-25-2013 05:23 PM |
