Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 04-13-2020, 02:24 PM   #15
PenGun
Drives: Red 2019 Subaru BRZ
LOL. I drove truck for a long time and shifted them without using a clutch, as that's how its done. I used the rev limiter seldom but it worked quite well. I had motorcycles as well and some of them limit shifted really nicely, off the limiter.
The post is certainly tongue in cheek as syncromeshed transmissions don't like no clutch shifting much, but I have done it anyway with several cars. Its hard to make em' shift well.
Certainly the limiter will be beyond the top of any power range, but the point of the exercise is to come into the next gear at a good point to lay down power.
PenGun is offline   Reply With Quote
Old 04-13-2020, 04:24 PM   #16
Ultramaroon
fabulous
Ultramaroon's Avatar
inb4 lol power
NoHaveMSG (04-13-2020), Tcoat (04-13-2020)
Old 04-13-2020, 08:52 PM   #17
PenGun
inb4 lol power
Yeah power. Its rather nice really, I have had way more, but this car just works so well once you use some RPM. I do it just to hear her sing.
Old 04-13-2020, 09:01 PM   #18
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
I'm puzzled how a rev limiter has anything to do with any kind of shifting.
soundman98 (04-13-2020)
Old 04-13-2020, 10:08 PM   #19
Ultramaroon
fabulous
Get a decent oil cooler. Don't cheap out.
Old 04-13-2020, 10:20 PM   #20
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Originally Posted by ZDan View Post
No, where the curves cross means nothing as far as optimal shift points. Crossover rpm is exactly the same for any engine, and only depends on what units you are using. English units, torque in lb-ft and power in hp are "equal" numerically at 5252 rpm. But this is meaningless as the units are different. In metric (N-m, kW), crossover is at a different fixed rpm (apparently 9543rpm), again for any engine or motor.
Optimal shift point for max acceleration would be to shift far enough *beyond* peak power rpm (which is 7000rpm for stock FT86) that you end up at the same power level at the reduced rpm in the next gear up. For us, we can't rev high enough so optimal shift point is at 7400rpm redline.
Thanks for straightening me out on the intersection question. My former rule of thumb gleaned a long time back was to shift at the power peak and set the gearing up so you land on or near the torque peak.
I'm still a little leery of the argument in the second paragraph, I understand maximizing the area under the curve but my experience on track suggests otherwise. Do you have empirical support for that assertion.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-14-2020, 01:27 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
Again, you'll want to shift *beyond* peak power rpm, and don't worry about where the peak torque rpm is. Doesn't matter.
Hopefully I can explain it such that empirical evidence isn't required:
What makes a car accelerate? Forward force applied at the rear tire contact patches. This force is a direct function of engine power, NOT engine torque which has to be multiplied by gear ratios to get rear wheel torque, and so depends on what transmission gear you are in.
Power is torque multiplied by rpm, and it is also force multiplied by velocity. 1 horsepower is 550 lb*ft/s. Forward thrust in pounds at a given speed is rwhp multiplied by 550 lb*ft/s divided by speed in ft/s.
Say you're at the track at 7000rpm in 3rd gear in a '13-16 FT86, making stockish 173 rwhp.
7000rpm, 1.541 3rd gear, 4.1 diff, 24.7" tire diameter => 119.4 ft/sec. Forward thrust at the ground is 173rwhp * 550 lb*ft/s per hp divided by 119.4ft/sec = 797 lb.
This is equivalent to running the *engine* torque through the gear ratios and dividing by tire diameter to get thrust at the rear wheels:
173rwhp at 7000rpm => torque = 173hp*5252/5700 = 130 lb-ft
130 lb-ft * 1.541 (3rd gear ratio) * 4.1 (diff ratio) = 820 lb-ft torque at rear wheels, divide by the tire radius or (24.7"/2) = 1.03 ft = 796 lb. Same result ignoring small roundoff error.
If you upshift NOW, at peak power at 7000rpm, you land in 4th gear at 7000*1.213/1.541 = 5510rpm. Power at 5510rpm is about 148rwhp, engine torque 141 lb-ft. So you're now operating with greater engine torque than you were at 7000 rpm, BUT torque at the engine is not what matters! Thrust or torque *at the wheels* is what matters...
Thrust force at contact patches is 148hp * 550 lb-ft/sec per hp divided by 119.4ft/s = 682 lb. of thrust, quite a bit less than in 3rd at 7000rpm...
Or calculating torque at wheels, 141 lb-ft * 1.213 * 4.1 = 701 lb-ft, significantly less than the 820 lb-ft in 3rd gear at 7000rpm.
701 lb-ft divided by tire radius of 1.03 ft = 681 lb. thrust (same as above calculation using rwhp and road speed)
Alternatively, winding it out past peak power rpm up to 7400rpm redline before upshifting to 4th:
At 7400rpm, power has fallen to 158rwhp, speed is now 126.2 ft/s
Thrust at contact patches = 158rwhp * 550 lb-ft/s per hp divided by 26.2 ft/s = 688 lb.
Or calculating from engine torque (158*5252/7400) = 112 lb-ft, way less torque at the engine, but again that's not what matters!
112 lb-ft * 1.541 * 4.1 = 708 lb-ft at the rear wheels
divided by 1.03 ft tire radius = 688 lb.
Upshifting to 4th at 7400rpm puts you at 5825rpm, at about 155rwhp (140 lb-ft). Note this is still a drop from the 158rwhp you were making in 3rd gear at 7400, so thrust still drops a bit, from 688 lb. to 676 lb.
Torque at the wheels is 140*1.213*4.1 = 696 lb-ft
TL/DR:
Between 81mph and 86mph (119.4 ft/s and 126.2 ft/s), you can either have 681 -> 676 lb. of thrust in 4th gear, or 797 -> 688 lb. thrust in 3rd.
Or in terms of actual rear-wheel torque, you can have 701 -> 696 lb-ft at the wheels in 4th gear, or 820 -> 708 lb-ft of torque at the wheels in 3rd.
More torque at the road wheels, more accelerative force if you keep it in 3rd all the way to redline...
Ideally you'd want to rev a bit higher than this even, such that you land at the same power level at lower rpm in the taller gear.
For best acceleration in this car, you'll want to rev to redline in every gear.
fwiw here's the rwhp dyno numbers I used in the above calcs:
The Following 4 Users Say Thank You to ZDan For This Useful Post:
Capt Spaulding (04-14-2020), Subsonic (04-14-2020), Ultramaroon (04-14-2020), WolfpackS2k (04-14-2020)
Old 04-14-2020, 02:40 PM   #22
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Exactly. For just about any naturally aspirated sports car you will want to shift at redline for maximum acceleration. Older cars and some pushrods are exception.
BRZ/FRS definitely needs to be taken to redline.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
The Following User Says Thank You to WolfpackS2k For This Useful Post:
Capt Spaulding (04-15-2020)
Rev limit oft Dragon780 Software Tuning 4 06-15-2017 11:00 PM
Roebling Aug 16,17 60 Car Limit Deep Six Southeast 5 08-08-2014 04:26 PM
What is this cars limit? JonnyJames Scion FR-S / Toyota 86 GT86 General Forum 49 10-16-2013 12:38 PM
No Limit Motorsport LeeMaster User/Vendor/Sponsor Reviews, Feedback, Comments 6 05-17-2013 01:16 AM
Rev Limit Acid18 Scion FR-S / Toyota 86 GT86 General Forum 36 01-13-2013 05:55 PM
