| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Red 2019 Subaru BRZ
Can You Limit Shift It?
When I was young, and had things with rev limiters, you could do really lovely shifts, by just putting pressure on the shifter, and just let the limiter make the shift.
Famous Potatoes
Drives: '15 ultramarine
limiter make the shift? What?
Drives: jrsc_brz
hes talking about clutchless shifting i believe. put slight pressure on the shift lever, and when you take your foot off the accelerator it comes out nice and easy then you can slide it easily into the next gear when the trans and engine speed is matched. i dont do it in my personal vehicle, because why the hell would you, but in the heavy duty trucks i drive a work, clutch pedals are only for starting and stopping, their transmissions dont even have syncros, rev matching is the only important thing.
no, i do not clutchless shift the brz after i banged it off the limiter wtf the posts you guys see come and go on this forum blows my mind
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
ProCrastinationConsultant
thanks, but i'd rather replace a clutch than the syncro's.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | spike021 (04-13-2020), Ultramaroon (04-12-2020) |
not playing cards
The limiter would have to have a tremendous amount of hysteresis programmed in.
It would still be way slower than a traditional, relaxed up-shift. For all but the most skilled operator, the syncros might as well be made of cheese because they'd last about that long.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (04-12-2020), Spuds (04-12-2020) |
yep. the clutch is made to be replaced. the syncro's require full transmission replacement...
Rust bucket enthusiast
I can't, but I'm sure you can!
Persona Non Grata
Drives: '15 BRZ (WRB)
I suspect you could do it. But, as others have pointed out, it would be 1) slower and 2) unless you are a shifting god, REALLY damaging to the transmission.
It's slower for a couple of reasons. Let's say the rev limiter kicks in at 7500. If it's soft limiter it may cut fuel or spark to a cylinder or two. The engine will not simply fall on its face. The idea behind what you want to do is to put pressure on the shifting mechanism and when the power cuts, the load on the transmission goes away and the pressure on the mechanism is enough to execute the shift as soon as the load is removed. This works quite well on constant mesh transmissions - think motorcycles. In fact, back when humfrz was a youngster it was the idea behind the first quick shifters on bikes. It does not work as well on synchromesh transmissions. So, if you're expecting the rev limiter to cut the power so you can gently slip into the next gear it's not going to happen. The rev limiter (if it's a soft one) will usually result in the engine developing a case of the blind staggers which even in the event you are the shifting god we mentioned earlier, won't take enough load off the transmission to get the shift done. So you're sitting there with your face hanging out and synchronizers in the the transmission turning to slurry and the engine banging and popping away. Ell seven - loser. The other reason it's slow is 7500 is way past the power/torque peak. My experience in my car is that the power begins to drop off as you approach 7000. After 7000 both of the stock engine's curves drop like a flume ride at six flags. You can push it farther, but that will slow you down. You're better off (in my opinion) shifting at about 6800-7000. That drops you down in to the mid 5000 range which is very close to the place where the engine's torque and horsepower curves intersect which is generally (again, in my opinion) where you want to be after an upshift.
Slow is smooth, and smooth is fast
| The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
#10 |
Drives: Crapcan
The window for floating gears on this car is pretty short. There is no practical reason to do it so why bother
![]() Shifting by banging the limiter is just....why?
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (04-13-2020) |
#11 | |
Wheels for Brains
Can you limit-shift on this car? Never tried it. However, the rev-limiter on the FRS/86/BRZ is a hard fuel cutoff. It doesn't bounce, so with that considered I am doubtful it will limit shift. |
#12 |
Drives: 2013 frs red
I've heard of shapeshifters
#13 | |
Drives: '23 BRZ
Optimal shift point for max acceleration would be to shift far enough *beyond* peak power rpm (which is 7000rpm for stock FT86) that you end up at the same power level at the reduced rpm in the next gear up. For us, we can't rev high enough so optimal shift point is at 7400rpm redline. Last edited by ZDan; 04-13-2020 at 12:10 PM. |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | Capt Spaulding (04-13-2020), WolfpackS2k (04-14-2020) |
#14 | |
Drives: Crapcan
HP = Torque x RPM ÷ 5252
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | p1l0t (04-13-2020) |
| Rev limit oft | Dragon780 | Software Tuning | 4 | 06-15-2017 10:00 PM |
| Roebling Aug 16,17 60 Car Limit | Deep Six | Southeast | 5 | 08-08-2014 03:26 PM |
| What is this cars limit? | JonnyJames | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 10-16-2013 11:38 AM |
| No Limit Motorsport | LeeMaster | User/Vendor/Sponsor Reviews, Feedback, Comments | 6 | 05-17-2013 12:16 AM |
| Rev Limit | Acid18 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 01-13-2013 04:55 PM |
