Old 04-06-2020, 05:01 PM   #15
extrashaky
Drives: 2014 BRZ Limited
Several years ago we had a "Hidden Features" thread that included all the little things they don't tell you about in the owners manual, like the gauge pass-through in the firewall, the cigarette lighter cap that exactly fits the sound tube to plug it, the hood prop that comes out so you can put it in a different hole higher up in the engine bay to stand the hood straight up, etc.
I don't recall ever seeing this charger pass-through one in that list. You may be the first to ever report it.
Originally Posted by ls1ac View Post
An other option is a small solar charger, run the wire out the back of the hood and in the door to the dash. I use one on a boat during the summer. I used to use one on a tractor before I got power to the barn.
If you use it a lot, you might consider just permanently running a wire through the gauge pass-through grommet I mentioned above. That way it doesn't have to go out and back in.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
aa_chow (04-06-2020), joro2 (04-06-2020)
Old 04-06-2020, 06:25 PM   #16
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
Yes, that hidden feature thread is awesome, learned a lot from it.
Sent from my HD1905 using Tapatalk
aa_chow is offline   Reply With Quote
Old 04-08-2020, 02:05 AM   #17
86TOYO2k17
Drives: 2017 toyota 86
Just go on a nice joy ride every couple days. You can be quarantined inside your car. If you aren’t driving for weeks at a time just unplug battery. You’ll have to relearn LTFT but not a big deal. I still say just drive it.
Old 04-16-2020, 04:41 PM   #18
G-awesome
Drives: 2015 Firestorm Scion FRS
I didn't even see the notch! I just leave the hood opened since it's locked in the garage anyways.
G-awesome is offline   Reply With Quote
Old 04-16-2020, 09:23 PM   #19
ls1ac
ls1ac's Avatar
I too like the Schumacher but it has one strange feature. If you try to charge a dead or near dead it will think it is a short and will shut down. You half to jump the battery to get the charge started. The better units have a high frequency de-sulfating setting for older batteries.
The Following User Says Thank You to ls1ac For This Useful Post:
soundman98 (04-16-2020)
battery
Search this Thread:
Advanced Search
Heater trickle and speaker grille rattle LudwigMiles Issues | Warranty | Recalls / TSB 14 09-07-2017 03:56 PM
USB charger: OEM fit mals Electronics | Audio | NAV | Infotainment 4 05-15-2015 11:18 PM
water trickle noise 'n' wet floor 2_slo Issues | Warranty | Recalls / TSB 7 09-27-2014 01:16 PM
Wireless Charger (aka Inductive Charger) in the Scion FR-S PhastekSport Electronics | Audio | NAV | Infotainment 2 01-01-2013 05:46 PM
New cars and tuning...will this trickle down to the FT86 LexusFman Engine, Exhaust, Transmission 1 12-15-2011 09:58 AM
