Drives: 2015 Scion FR-S TRD
So, i’ve recently bought some spec d headlights, because the ones that were currently in the car are cracked with water in them. With doing so, i wasn’t aware my frs had a 8 pin headlight harness. The Spec D headlights come with a 6 pin. Instead of cutting, splicing and rewiring these bad boys at a shop (i’m bad with wiring, first timer) i wanted to just plug and play. Then i could just t tap the spec d wires into where it’s needed. Where could i find some 8/6 pin headlight harness adapters that would fit ? I found a website which is strictly australia only and one on ebay, which seems a bit sketchy.
| Tags |
| 8/6 pin headlight harness, brz, frs, spec d headlights |
| Spec-D headlight DRl Mod | amngmac | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-30-2016 02:50 PM |
| WTB Spec D headlight | mythhelios1 | Want-To-Buy Requests | 1 | 09-22-2015 05:42 PM |
| Spec d headlight. | Chen | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 07-21-2015 04:10 AM |
| Spec-D Headlight Question | iStanley | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-10-2014 07:44 AM |
| Disconnecting battery for installations | i_4got | Electronics | Audio | NAV | Infotainment | 2 | 11-21-2012 02:04 AM |
