#15 |
Drives: 2016 Hot Lava MT
| The Following User Says Thank You to Hot-Lava_Dave For This Useful Post: | soundman98 (03-27-2020) |
#16 |
Drives: 2020 Hakone Edition, 2015 FR-S
I had a burning smell for nearly 10k miles in my 2015. Got fixed when they did the 60,000 service (with spark plug change). It was a leaking right side valve cover. Leaked a small amount of oil on to the catalytic converter attached to the header.
PS. Mice and chipmunks love the plenum on the inlet side of the engine air cleaner and the cabin air intake. I had an eaten through cabin air filter in my 2015 removed and the whole system cleaned and disinfected. I also pulled my engine air filter and checked for acorns every fall and spring. |
#17 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
| The Following User Says Thank You to Vracer111 For This Useful Post: | TofuJoe (03-28-2020) |
#18 |
Feeling like thinking....
I had two leaks on my 2013 MT FRS.. cam cover plate, which dealer attempted to fix twice unsuccessfully and I finally fixed using the Racesent part, and the timing chain cover, which the dealership also did under warranty... and overdid the sealant, which according to their mastertech who did my valve spring recall a year later contributed to the grenading of my enging 600 miles after the recall job. Have them check your timing chain cover. If it is leaking, make SURE they follow, exactly, the amount, locations, and type of sealant to be used.
Drive like everyone's life around you depends on it...
#19 |
Drives: 2013
My battery positive terminal shield fell off and melted over the exhaust. Smelled like burning plastic for awhile although a mechanic should see that quick enough...
| Burning smell after FP/OP mod | mr_squirrel | Engine, Exhaust, Transmission | 3 | 10-30-2017 12:04 AM |
| '17 BRZ burning smell | Zoh | Issues | Warranty | Recalls / TSB | 28 | 05-15-2017 12:09 AM |
| Burning smell | Riftur | Engine, Exhaust, Transmission | 9 | 04-13-2016 02:50 AM |
| Burning smell PLease help! | Chase1996 | Issues | Warranty | Recalls / TSB | 62 | 11-02-2015 02:11 PM |
| Anyone smell burning outside the car? | DarrenDriven | Scion FR-S / Toyota 86 GT86 General Forum | 115 | 01-13-2015 02:31 AM |
