#29 | |
Drives: Miata
Are people typically getting 10% of their roll stiffness from bars? More? 15% - 20%? What spring rates/bars would you recommend on an STX autocross car on 200TW tires? |
#30 |
With the MCA springs of 6kg front, 4.5 rear and stock bars, my car was pretty sweet on Hankook RS4's for both street and the occasional autocross.
If I was more serious about autocross I would maybe dial in a bit more oversteer. Meh, compromises. I also swapped the RS4's for RE003's, bad move by me. RE003 are rubbish compared to the RS4's, and by rubbish, I mean rubbish, the RS4's are better everywhere, except when it's wet, the RE003's are "slightly" better, but not worth it in the end. Lessons learnt and all.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#31 | |
I think the OEM bar is more than 50% of the total wheel rate up front with stock springs. It's in my notes. Less than 50% for the rear since the bar is small and the motion ratio of the bar is lower. - Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#32 | |
Hole 1/1 = 299 lbs/in Hole 1/2 = 323 lbs/in Hole 2/2 = 346 lbs/in Hole 2/3 = 375 lbs/in Hole 3/3 = 404 lbs/in Hole 3/4 = 440 lbs/in Hole 4/4 = 475 lbs/in Mann Engineering Rear Rates: Hole 1 = 75 lbs/in Hole 2 = 53 lbs/in Hole 3 = 43 lbs/in I have rear BRZ/FRS Bar (14mm) at 111 lbs/in rear 86 bar (15mm) at 146 lbs/in
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | RedReplicant (05-01-2023) |
#33 | |
- Andrew
Website
#34 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
For what it is worth, when I did the math last year I arrived at the following OEM 2013 BR-Z rates at the wheels (not including dampers):
Front Springs: 138 lbs/in Sway Bar: 126 lbs/in Rear Springs: 110 lbs/in Sway Bar: 28 lbs/in (36.5 lbs for PP 15mm) So yeah, front is getting nearly 48% of its spring rate from the sway bar. In the rear its more like 20%. Performance Pack numbers are obviously different. To the OP's original question, I run the Performance Pack suspension (including rear SW) with the stiffer 2013 brz rear springs, and a 19mm Perrin front bar. Love the setup with -2 front camber. For a street car and my application, the chassis SINGS through corners. Last edited by BlueWhelan; 02-21-2020 at 01:28 AM. |
| The Following User Says Thank You to BlueWhelan For This Useful Post: | Racecomp Engineering (02-24-2020) |
#35 | |
Drives: Miata
And it appears STX guys are going with similar percentages? Thanks for the info gentlemen. |
#36 |
Drives: unlimited cheap build N/A track car
It makes sense that the cars balance would change to more understeer with only a stiffer front bar installed. Its not a driver error thing. Install a stiffer rear if you like the reduced body roll, or go back stock.
#37 |
Drives: 2017 PP BRZ
I have Whiteline adjustable sway bars front and rear! I am running 20 mm up front and 16 mm in the rear.
#38 | |
Drives: FR-S Whiteout
On stock components pieced together. BRZ front, FRS Rear springs rates off the first generation and newer shocks. I've gone with a 19mm perrin and felt too 'pushy' for my use even at the softer setting. I'm sure its much different for autocross use and with double or triple the spring stiffness. I do like the idea of soft rear sway bar or even delete as Robispec ran back when this car just came out. With stock springs it would just bottom out without the rear sway. Really good traction on the throttle before it hits the bumpstops tho.
Intent > Content
cowardice is the mother of cruelty. |
#39 |
What's alignment? Car isn't that pushy if you get the front tires on the ground so they're happy.
Most of these cars are setup around how aggressive owners are willing to align it. |
#40 | |
I also tend to drive using generous amount of trail braking. I need to work on that.
Intent > Content
#41 | |
What Sway Bars Work Best For You?
As Strat asked, what camber are you running in front? I run BRZ front and '13 rear springs as well with a Perrin 19...with -2 camber the front isnt that understeery. The rear sway bar motion ratio is pretty mild compared to the springs, so if you soften (or remove) the rear bar it won’t take out that much spring from the system. You probably won’t be on the bump stops much more than you already are (given that these cars are already very bump stop active), however the balance will shift to even more understeer. If that’s what you are looking to avoid, then it’s probably not the best option. I’d say add more camber, depending on where you’re already at. Edit: ah you beat me to the post and answered my question. Sent from my iPhone using Tapatalk |
#42 |
I'm at -4 up front, so are others who are way faster than me.
Edit: car is sprung as soft as you can to get the roll stiffness to work out, I want it to soak up pavement imperfections, the front geometry seems to just love a stiff bar (relatively speaking when the baseline is stock setup). I try not to overthink it too much these days other than some black magic with the lump of an engine over the front and roll centers. Last edited by strat61caster; 03-07-2020 at 07:21 AM. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Icecreamtruk (03-09-2020) |
| WTB Sway Bars | MrAsh2222 | Canada Classifieds | 4 | 03-24-2019 04:19 PM |
| FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars | armyoffoo | Brakes, Suspension, Chassis | 10 | 08-08-2018 09:28 AM |
| WTB F&R sway bars | blkmamba | Canada Classifieds | 1 | 06-04-2017 03:15 PM |
| FR-S stock sway bars compared to TRD bars | babydriver | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-01-2014 10:12 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 07:00 PM |
