Old 02-12-2020, 07:29 PM   #15
Stock front, 17+ rear.
Old 02-12-2020, 11:42 PM   #16
gcranston
Drives: 2015 Subaru BRZ Limited DGM
2017+ stock rear, or 17mm+ rear? Just to clarify...
gcranston is offline   Reply With Quote
Old 02-13-2020, 01:47 PM   #17
doodoobrown
doodoobrown's Avatar
Interesting note - the guys testing the Xida coilovers with 949 racing were setting N/A track records last year in NorCal and SoCal on a 22mm front sway bar with OEM rears (14mm).
doodoobrown is offline   Reply With Quote
Old 02-13-2020, 02:16 PM   #18
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by prandelia View Post
The more spring you have, the less bar you need. Auto-x'ers and casual track tend to be softly sprung and use more bar, race cars are a lot stiffer and need less bar.
I'm on 700/900# springs, and only need a 20mm front, 16mm rear bar setup. Works perfect, same size as TMG racing cars in Germany.
Not trying to start a campfire here, just wanted to point out that I though this was exactly how it works. Yet my experience with my own car was that the setup improved with stiffer bars (similar ratio increase to OEM, around 200% stiffer front and rear), for a car on 12k springs.
So a big "it depends" on this, or anything related suspension setup for that matter.
Old 02-13-2020, 04:07 PM   #19
86MLR
86MLR's Avatar
With my coilovers and tyres, and alignment settings, stock are going well.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 02-13-2020, 06:47 PM   #20
prandelia
Drives: 2015 FRS
I agree, I'm speaking in generalities. That's also why swaybars have adjustable holes to allow handling preference. FYI - a 20mm front swaybar with 2 holes provides around 120% and 175% stiffness increase over stock, so my setup is pretty much the same, not even accounting for shock settings and alignment.
Another big variable is tires and weight. At my weight (2390# no fuel), I can only race on 225 wide hoosiers, so others may squeeze a lot more tire, or be heavier, thus allowing for bigger bars.
But in general, once you get to "real" race car spring rates, you don't need as much bar as say, an auto-x-er who wants a 25mm front to keep the strut from moving.....All good, I'm happy to see somebody else who has some real spring rate under the car, it needs it!
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
The Following 2 Users Say Thank You to prandelia For This Useful Post:
CSG Mike (02-13-2020), Icecreamtruk (02-14-2020)
Old 02-13-2020, 08:37 PM   #21
TommyW
TommyW's Avatar
Drives: '13 Whiteout
This is like asking what tire pressures are best.
Old 02-13-2020, 08:37 PM   #22
2017+ OEM rear, which is 16mm
Old 02-13-2020, 08:38 PM   #23
Also of interest, is that the 949 Racing FRS is more extensively prepared than essentially any other 86 out there. With extensive modification, tuning/balance changes will also be altered.
The original question set by the OP says it best; many people drive faster when the car is set to their preference.
Don't forget that the sways are only one component of net wheel rate.
Tcoat (02-13-2020), TommyW (02-13-2020)
Old 02-13-2020, 10:23 PM   #24
prandelia
Drives: 2015 FRS
I will say one thing. I wish Whiteline just welded a collar on the bar, the adjustable shaft collars that come with the sways are total garbage. I replaced them with a set of aluminum Rulands that actually work.
'15 FRS - GLTC spec
Old 02-14-2020, 02:52 AM   #25
86MLR
86MLR's Avatar
34 psi of courze, unless your on a courze, and dependant on tyres, oh and track temp, and whether it's raining, or your just Hwy driving looking for fuel economy, or at the drags.
And the string is exactly 2000mm long, dry.
Old 02-14-2020, 04:20 AM   #26
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You don't see the irony there? You're rounding up from 1999.87 mm
Old 02-14-2020, 06:35 AM   #27
86MLR
86MLR's Avatar
And I'm going to party like it's 1999.87
Edit: or 2187.084427
for the imperialist.
Not as catchy though.
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
Captain Snooze (02-14-2020), StraightOuttaCanadaEh (02-14-2020)
Old 02-14-2020, 09:54 AM   #28
M0nk3y
I mean...my strut moves
Adjustability allows going from that to dealing with damp conditions (If you look at the tires, we're actually loading the front properly here).
Final point - just make sure whatever you choose you have the tuning tools necessary to setup the car for whatever conditions you're going to be running in.
Kyle H. - #89 STX
WTB Sway Bars MrAsh2222 Canada Classifieds 4 03-24-2019 04:19 PM
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars armyoffoo Brakes, Suspension, Chassis 10 08-08-2018 09:28 AM
WTB F&R sway bars blkmamba Canada Classifieds 1 06-04-2017 03:15 PM
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 10:12 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
