Old 02-08-2020, 06:54 PM   #29
p1l0t
p1l0t's Avatar
Did you overtighten the rotor?
Old 02-09-2020, 01:25 AM   #30
Ha1i8ut2
Drives: 2015 brz
I don't think so, its the same as the other side now. Just to the point where it doesn't move and the dimple Is in the cutout
Ha1i8ut2 is offline   Reply With Quote
Old 05-18-2020, 03:48 PM   #31
jfarrell44
Drives: 2017 Toyota 86
Was there a resolution that you ever found to this? I have experienced a similar situation, without going into too much great detail. I am researching my options before my next move.
Thank you
jfarrell44 is offline   Reply With Quote
Old 07-06-2020, 09:46 PM   #32
Ha1i8ut2
Drives: 2015 brz
Ended up being a broken wheel bearing. If it gets just the slightest bit too far away from the sensor the car will go into limp mode.
The Following 3 Users Say Thank You to Ha1i8ut2 For This Useful Post:
Alpha_noob (01-11-2021), bcj (07-07-2020), p1l0t (07-08-2020)
Old 01-11-2021, 09:06 AM   #33
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
Thank you so much for your in-depth analyses on this on this issue. I've recently (since yesterday) been experiencing the EXACT SAME issue you described. Cleared codes and everything. Car is in limp mode, with the TCS, ABS and CE Lights on.
My limp mode started when I was polishing my wheels. I jacked up the rear of the vehicle and ran the car in 2nd gear to spin the wheels so I can easily polish them. after about 20 seconds or so (cant fully remember) the fans came on and the car threw the 3 orange lights on the dash.
However, I've been getting wheel bearing noises on the highway pretty much constantly recently. And have been lazy to fix it. At least this forum makes me confirm that the noise I've been hearing is a damaged wheel bearing.
I would have never thought that was the issue. I will have to locate the damaged wheel bearing and revert back.
OP did you clear the codes after changing the wheel bearing? And did that fix the limp mode?
Warranty claim, here we come.
There's no point in owning an 86 when you like to sell your cars at low mileage
Alpha_noob is offline   Reply With Quote
Old 01-11-2021, 09:54 AM   #34
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
Here's a video on another person fixing the same issue via rear right sensor replacement after replacing their broken/rusted wheel bearing.
v=o6H8HX1Ispg
Old 03-06-2021, 10:50 PM   #35
Arvin
Drives: Subaru BRZ 2016 auto
Hi bro we got a similar problems and I found a sensor at the back under the boot floor attached to the axle broken in half or moved it looks related to the brake not sure it I am sure all problems coming from that sensor
The part number is B155444-1 and there is a number 511612 on top of the part number
I am trying to find the name of the part then ordered one of that then will so how thing will go ahead
Arvin is offline   Reply With Quote
brz, engine light, p2158, speed sensor
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 05:05 PM
P2158 Speed Sensor SimbasSon Issues | Warranty | Recalls / TSB 4 07-21-2019 06:25 PM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open Rossi AFRICA 18 02-02-2016 06:26 PM
Get a JSC Speed "Some Assembly Required" BRZ Shirt Free! JSC Speed Announcements, Contests, Giveaways 0 11-08-2012 03:34 PM
