#85 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
#86 |
Drives: Raven black manual transmission
I bet.. I'll wait until I change out these port fuel injectors and buy aftermarket fuel injectors before I manipulate the fuel injector latency timing because when you buy aftermarket fuel injectors one of the main prerequisites for proper operating uses is to follow there installing guides, its normally a given that the aftermarket fuel injectors come with latency timing reprogramming details for software tunning , and your darn right I'm using wjstever installations values they give for proper installation purposes.. Lmao
#87 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#88 |
It's to my belief that it's possible that Toyota and Subaru share holders may have invested in the hardware.. The hardware was made available to the public to be purchased very close to the release of the 2013 scion frs in the USA; so I think it's safe to say Japan had there hand in this a bit earlier.. If I was big time in cash flow dividens I would have thought of it as an investor in the stock market, after all they are public for share holding.
#89 |
ProCrastinationConsultant
lolololololol. subaru and toyota have never had anything to do with ecutek
| The Following User Says Thank You to soundman98 For This Useful Post: | KR-S (01-25-2020) |
#90 |
Connection issues
Drives: '15 ultramarine
This just keeps getting better and better..
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | KR-S (01-25-2020), soundman98 (01-25-2020) |
#91 |
this is becoming a dinner for schmucks kinda thing...
#92 |
Yea you deffinitely can get it up to +380 hp with a stock FA20 block but if your using stock port injectors your duty cycle will definitely be around or over 85% and according to fuel injector guide installions it's noted that the duty cycle should be at (X<=80)% or (X<= 75)% under safe operating conditions. I was informed in a forum with test studies to back it up with graphs attached that out stock port injectors are operating at approximately 54% .. So it would be wise to shop around and by new port fuel injectors that are rated for 350cc/min or greater.. I'm operating my vechicles fuel injectors at a duty cycle of approximately 71%, with these stock port injectors this may be the highest duty cycle I'm willing to push my stock port injectors under my ecu tune..
| The Following User Says Thank You to Payload For This Useful Post: | SuperTom (01-25-2020) |
#93 | |
Best ever!!!!!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#94 |
Who knows, keep in mind Toyota and Subaru are open to the public for investors so anyone holding shares could be potentially working with ecu tek.. I didn't say its a definite but it could be a possibility..
#95 | |
Sporadic Member
#96 |
Sporadic Member
You know what, anything this guy says is worthwhile copypasta material. He just literally posted the same thing just now.
#97 | |
Drives: Subaru
I didn't know that, but that's exactly the type of stuff why I don't really want to get into adding a turbo into an N/A vehicle. A factory turbo vehicle has all of that stuff already worked out.. Things are just made to stand up better to the demands FI puts on them. Usually. I think Payload needs to start his own HiJack somewhere else. |
#98 | |
You ARE not going to get anything even remotely close to your claimed gains by swapping some injectors and adjusting a tune.There are thousands of threads on increasing power on here and yours is the most ludicrous of them all. Link some evidence that what you claim is real and become the hero of the internet or shut up and maybe the guys will go easy on you but at this point you are just making a fool of yourself.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | KR-S (01-25-2020), soundman98 (01-25-2020) |
| Thoughts? | adjusts | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 11-23-2016 10:25 AM |
| THOUGHTS? | Darkparadox911 | Southern California | 11 | 07-23-2015 01:37 AM |
| Any thoughts? | imjuice | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 05-17-2014 02:35 PM |
| Thoughts on this. | Style | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 08-03-2012 02:59 AM |
| Brief thoughts on my new FR-S | mickey177 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-17-2012 04:37 AM |
