Old 01-14-2020, 08:00 PM   #1
COLETRICKLE
COLETRICKLE's Avatar
Drives: Scion FR-S
2016 FR-S Radio skips
My radio sometimes skips when I listen to music on the radio, iPhone, Bluetooth.
It mostly happens when I raise the volume, it does it most of the time when I raise the volume past 23.
I know the stock radio sucks, dunno what can cause this...
Thoughts, I tried searching forum hardly anything pertains to my issue.
COLETRICKLE is offline   Reply With Quote
Old 01-14-2020, 10:05 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
So all factory radio?
No subwoofer amp or other add on's?
If there are add on's then their is your problem, you have a loose connection or something is shorting out.
If all else fails take out the stereo carefully, and check that all the wires are plugged in properly or if some one did a hack job and return to stock.
If that doesn't work, then a trip to any car audio place might be in order. Good luck.
The Following User Says Thank You to Mr.ac For This Useful Post:
COLETRICKLE (01-18-2020)
Old 01-18-2020, 01:21 PM   #3
COLETRICKLE
Drives: Scion FR-S
Everything is OE, nothing aftermarket. I’ll check to see if anything is loose.
BRZ apple carplay skips/glitches prizmracer Electronics | Audio | NAV | Infotainment 10 03-28-2019 03:21 PM
2016 brz premium steering wheel, radio, door panels, rear seat belts/ seat brackets. Joesurf79 Interior Parts (Incl. Lighting) 12 06-01-2018 11:51 PM
2016 brz radio in 2013 frs no door speakers Adamf220 Electronics | Audio | NAV | Infotainment 4 05-30-2018 10:23 PM
2016 RADIO USB/IPOD WONT STAY SET? STEWARDORNG Electronics | Audio | NAV | Infotainment 1 12-16-2015 04:28 PM
A2DP Bluetooth Skips bdbx18 Electronics | Audio | NAV | Infotainment 9 05-28-2013 11:14 AM
