Old 10-06-2020, 08:18 PM   #365
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by Autoenthusiastasm View Post
If I want around -2.5 chamber in the rear can I get there without LCA’s?
If you're going stock height and no LCAs you won't even get past -1.5 and you'd be lucky to get that much.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 10-07-2020, 07:23 PM   #366
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Good to know, I’ll add the white line LCA to my list. Thank you.
I’m guessing that at near stock height and 2 1/2 . 245/40 should clear the fenders without rubbing.
Autoenthusiastasm is offline   Reply With Quote
Old 10-08-2020, 08:23 PM   #367
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Correct. Just run a +35mm - +40mm offset wheel.
Breezio is offline   Reply With Quote
Old 10-08-2020, 09:40 PM   #368
Autoenthusiastasm
If I have camber plates , running near stock height, will I need crash bolts to get to -4 - -4.5
Old 10-12-2020, 03:01 AM   #369
Locust
Custom User Title
Locust's Avatar
-4.5 is too much camber. And probably unless your camber plates are insane.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 10-14-2020, 09:10 AM   #370
RRslip
Drives: Black BRZ - STX
I need to keep the height near stock because I daily and winter drive my car.
I was going to go with LPC LCA but I guess they are illegal u less bushing is changed out.
The good thing about coilovers is that they go up and down. Just raise the car for the winter...
One thing to consider with those LCAs (assuming "LPC" was supposed to be "SPC") is that you'll need an alignment anytime you disconnect the LCA. Like, to change springs or change an axel etc. You'd break even after 1 alignment if you go with a better adjustable LCA.
RRslip is offline   Reply With Quote
Old 10-14-2020, 09:27 PM   #371
Autoenthusiastasm
One thing to consider with those LCAs (assuming "LPC" was supposed to be "SPC") is that you'll need an alignment anytime you disconnect the LCA. Like, to change springs or change an axel etc. You'd break even after 1 alignment if you go with a better adjustable LCA.[/QUOTE]
I was thinking white line , LCA. What do you recommend and why. G to make informed decisions so I only buy once.
For wheels. If I went 45 offset, could I get by with a 5 mm spacer to fit.
Old 10-14-2020, 09:29 PM   #372
Autoenthusiastasm
From my research, most are running -4.5 up front. How are people getting that much?
Old 10-14-2020, 10:33 PM   #373
strat61caster
strat61caster's Avatar
Either two camber bolts in oe holes or the strut is slotted and a straight/oe fat bolt is used with a lobed bolt in the bottom. With camber plate of course.
My Megan's are the latter and I've got space to go to at least -4.5 if not a little more but I'm not sure I could hit -5 on both sides. I'm at -4.3 and I plan on backing down to -4 when it next goes on the rack and adding a bit of toe out to see if that helps Street driving tire wear.
I had two lobed bolts (16/14mm) in my bilstein which has oe spec holes and I believe I never maxed it out either but went up to about -3.7 degrees (with camber plates), -4 should have been possible iirc but -4.5 might have been a stretch, slotting or enlarging the upper strut hole likely would have done the trick is I wanted more.
You could also put an offset bushing in the lca like this one. I don't know if it's STX legal though with the silly metal content rules.
https://www.powerflexusa.com/shop/pr...BoCzIUQAvD_BwE
And some coilovers are just made different to allow more camber iirc the 949 xidas will hit -3 degrees or more on oe top hats which is neat.
ineedyourdiddly
Autoenthusiastasm (10-15-2020)
Old 10-16-2020, 10:27 AM   #374
RRslip
I have the Verus LCAs, they're solid.
Agreed on front camber, you'll want to be over 4 degrees. How to get there depends a lot on your coilovers, some are more slotted than others at the knuckle mount. I have RCE Tarmac 2s and Ground Control top hats. I'm around -4.2 with the OEM bolts and still have room to get more at the hats.
Old 10-18-2020, 09:38 AM   #375
scirocco78
Drives: Scion FRS
I've been running 4.2ish negative camber on Tarmac 2's and RaceEng camber plates for a couple of years now. I can't get anymore because of the sway bar end links. They hit the body and and I can't turn the wheel. White line end links BTW.
scirocco78 is offline   Reply With Quote
Old 10-21-2020, 02:22 PM   #376
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Get smaller end links, the Whiteline links are great for durability but *really* chunky.
-4.2 to -4.5 should be about enough though, IMO.
Old 11-23-2020, 10:35 PM   #377
Autoenthusiastasm
The tire rack TR motor sports are +45. They are fairly light 19,8 and dirt cheap at $120. I would probably need a spacer (guessing 5mm). Would I have to extend the lug bolts? Not really interested in the hassle, I don’t have an impact wrench
Old 11-24-2020, 12:23 AM   #378
Breezio
Breezio's Avatar
You might clear with that setup and no spacer, but I don't have a lot of knowledge in the area.
I'm lowered a fair bit on my coilovers, running 17x9 +40mm wheels, 255/40 tires and -3.8 camber in front. I rub when turning the wheel to lock either direction, but otherwise it's good.
Search this Thread:
Advanced Search
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 110 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 11:05 PM
