86WORX
Old 10-04-2020, 09:49 AM   #351
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by BlueWhelan View Post
Tire pressures in PAX is not an apples to apples comparison. What car/setup/tires was this person running, and what car/setup/tires are you running? Just because something works for him/her doesn't mean it'll translate to your setup. Some race slicks are designed to be run below 20PSI, so it's not unheard of. However, its unlikely 20psi is going to suit your needs.
That said, the real test: how did it feel once you did? Did it get better or worse?
i mean he literally said what you said and to try it out and ask a forum. so here i am. at 21 it felt ok but i still could feel break away. thus me asking in this thread
Breadman is offline   Reply With Quote
Old 10-04-2020, 11:54 AM   #352
strat61caster
strat61caster's Avatar
Which tires, size and wheel size are you using?
I've never run lower then 26 psi hot, started feeling inconsistent for me. I usually set at 29 psi hot and bleed down to 28-30 based on balance. Re71r 245/40/17 17x9, I've heard bfg and yoke like 1-2 psi more.
20 psi sounds like Hoosiers on a <2200 lb car pressures, not really relevant to this car/class.
Edit I see the size now, still curious about compound and I've run these pressures down to the low 50s, ambient and in the damp/wet. When it's chilly you usually have less grip as the tires don't stay warm, everyone is dealing with the same thing and it's just something to drive around imho
ineedyourdiddly
Old 10-04-2020, 12:04 PM   #353
racingfool
racingfool's Avatar
Drives: Miata
racingfool is offline   Reply With Quote
Old 10-04-2020, 12:26 PM   #354
Breadman
Breadman's Avatar
ok let me restate my question, i run 255/40/17 RE71rs. i normally run 24psi but was having sever rear grip issues in the cold at that psi. what pressure should i run them at since i have 2 more events this year and it probably will be just as cold
Old 10-04-2020, 12:52 PM   #355
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Since I知 not planning on changing exhaust or header I would be only stage 1. Seems like a lot of cash for a single use unless it has a big improvement on tourqe and flattens the dip so to speak
Autoenthusiastasm is offline   Reply With Quote
Old 10-04-2020, 05:07 PM   #356
strat61caster
It's third on my list of priorities for a reason.
Once you get the wheels/tires/suspension sorted the 15 hp from header+tune is the next few tenths to the pointy end.
ineedyourdiddly
Autoenthusiastasm (10-06-2020)
Old 10-04-2020, 10:54 PM   #357
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
24 psi seems really low to me. What are your camber settings?
I run 255/40R17 as well, but A052s. I don't dare go below 29 psi in the front as I'm already a bit warmer on the outside shoulder with some extra wear. Currently running -3.8 front camber
Rear I'm at 27-28 psi with -2.5 camber.
If it's cold and your having traction issues, it's probably not a tire pressure problem. Might just be because it's cold. Or perhaps it's cold and your tires are starting to heat cycle out.
Breezio is offline   Reply With Quote
Old 10-05-2020, 11:03 AM   #358
steverife
Drives: 2016 Scion FRS
I've never ran my car on Bridgestones, but 24 seems really low. Especially for 255's.
As far as adapting to lower temps, blankets help. And don't open your hood.
Another thought, and something I've played with at some colder events, is to take a sacrificial run with traction control on and hope to retain some of the heat that generates.
steverife is offline   Reply With Quote
Old 10-05-2020, 12:04 PM   #359
Breadman
Breadman's Avatar
i thought about them being heat cycled out since ive been running pretty much every weekend this year. but i have the same camber more or less. -3.7 front -2.5 back. i asked one of the really good stx drivers what psi i should be at at the start of the year and he said 27 front 26 back but to check the indicator and temps since im on 255s and not 245s. i ended up dropping to 24 to get to the indicators
Old 10-05-2020, 12:40 PM   #360
ka-t_240
So I知 tired of getting my butt handed to by Type R痴 and RS痴. So looks like STX is where I知 going. This is what I知 thinking, RedShift Competition Coilovers, looking at 7k F/R. (400#). Seems like Perrin 22mm bar is most common. I was going to go with LPC LCA but I guess they are illegal u less bushing is changed out. I need to keep the height near stock because I daily and winter drive my car. If I want around -2.5 chamber in the rear can I get there without LCA痴? I am not changing my exhaust . Is the improvement in tourqe with the Unequal length header worth it? I知 Keeping my 7.5 wheels as I have brand new 225 Re 71s and need to use them up or sell before I get my 17x9 wheels. Do I need new endlinks for the front if ride height is near stock? Do I need the subframe (bushings - what do they do?). Is the tablet worth if exhaust is stock. I知 trying to spend my money wisely as my wife is keeping tabs. Not looking for National level build but competitive local mid sized region.
Have you considered SSC or do you want to bite the big bullet and go to STX?
ka-t_240 is offline   Reply With Quote
Old 10-05-2020, 12:42 PM   #361
steverife
I don't think those are supposed to be indicators.
Old 10-05-2020, 07:34 PM   #362
Autoenthusiastasm
I posed that question before and some say the ssc has some unusual handling characteristics. Plus there are not many running ssc. Lots running STX. The BRZ seems very competitive in STX.
Old 10-05-2020, 10:04 PM   #363
Breadman
Breadman's Avatar
well shit. this might not be relevant soon anyway, i might be selling it to get a more "practical" and "family car" my wife wants me to get. time to boost a wrx until it blows. sadly ill probably have to return it to stock, sell that, so watch for a part out in December
Old 10-06-2020, 11:01 AM   #364
steverife
It is better with the new tire and adjustable end link allowance.
With that said, having competed in both, the car is WAY more fun with a header/tune, so I would recommend those. The car with my STX exhaust really isn't any louder than it was in SSC with the Nameless muffled track pipe.
Search this Thread:
Advanced Search
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 110 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 11:05 PM
