#281 | |
Drives: 2017 BRZ w/PP
i do have them in the lower, i think i slightly nudged my subframe since the other side was over 4 on the initial measurement on the rack. also i did not know you can use a camber bolt in both holes. is it the same one and just point them in the other direction? |
#282 | |
https://www.ft86club.com/forums/showthread.php?t=103609 |
#283 | |
my subframe must be jacked up because i moved the bottom oem bolt to the top and have the 14mm spc bolts on the bottom with full camber, and my camber plates maxed and only hitting -3.7. ill have to take a look some time before next year. i my wallet doesnt need a 3rd alignment this year. also just got done adjusting my front sway bar. got 1 side on stiff, one side on soft, lowered it, took all the preload off, and drove around in an empty parking lot. no clucking, feels really good and nimble. well see how this weekend goes |
#284 |
Drives: 2017 BRZ Premium
Made it to my first event post tune and header install.
This is a local club that runs a pretty big/wide open autocross once a year at a larger venue (former SAC base) Car feels great with the extra power, couple spots where third gear would have been ideal, but after trying on 1-2 runs I didn't find it was worth it. 17' BRZ base Drivetrain: Ace350 Motiv HFC Tanabe Concept G Catback Whiteline positive shift bushing ECUTek via Zach Tucker/CSG Suspension: Ohlins R/T's (early version w/plates) Works motorsports swift upgrade: 6Kf/7Kr Whiteline 24mm front bar - Soft Whiteline front endlinks Blox rear camber arms (poly inner bushing) Wheels/Tires: 17x9 +40 Konig Hypergrams 245/40r17 RE71r Alignment: Camber: 3*f/2*r Toe: 0 front - 1/16" Toe-in rear Car overall feels pretty neutral with a hit of understeer on the wider sweepers, could be more a nut behind the wheel issue. Haven't fooled with the dampers at all, ride height is set based on ohlins out of box recommendations with rebound set on mid setting. Fastest from day 2, 3rd pax / 8th raw overall: |
#285 |
Moutain Runner
So my FA coilovers are essentially maxed on camber. I'm sitting at -2.5F/2R. To get to -4, I'd need camber bolts mentioned above, correct?
#286 | |
***** Lurker
Drives: 2015 BRZ
So after chatting with Lugod, I moved to the 5K/9K setup for this year... Now the car just feels silly to drive and the only time I get any understeer is when I completely overdrive the corner entry. But when that happens, I can get the car to quickly recover as opposed to the square setup, where overdriving an entry meant suffering for a while before I could get back on throttle... But of course, I drove like garbage at the Pro... |
#287 |
Drives: 2016 Scion FRS
Are all the people discussed on the 5k/9k setup running a Giken?
#288 |
Drives: Miata
#289 |
Drives: FR-S - STX
Pretty sure they are on the OS Giken LSD with 5k/9k.
Does anyone have corner balancing corner weights to share? |
#291 | |
LF: 793 RF: 760 LR: 673 RR: 608 180 lb ballast in driver seat
Kyle H. - #89 STX
| The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | Roadphantom (08-17-2020), strat61caster (08-17-2020) |
#292 |
Drives: Miata
So what bars go with the 5k/9k set up?
#293 |
On this board, people with that setup were running the Perrin 22mm bar on stiff and the Mann rear bar, but that was before the Karcepts bar was available...so some may have upgraded.
I don't think this is a one size fits all answer. |
#294 |
Suspension Nerd
Drives: 2019 Mazda MX-5
OS Giken / Bridgestone / Lot-USA BRIDE
| The Following 3 Users Say Thank You to oinojo For This Useful Post: |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 03:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 12:27 PM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 12:30 PM |
| Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 11:05 PM |
