#183 | |
Drives: STX FRS
And Yea, in previous cars I've found HPS to be an overpriced garbage pad that was stock equivalent if not worse. I'll swap something a bit better in at some point Honestly I doubt I'd change anything before first autocross back (whenever the heck that will be) but may try connecting rear bar should time allow between runs. |
#184 | |
#185 |
Drives: 2016 Scion FRS
It was surprisingly easy to put the DIFtech bushings in the SPC arms. Used HF press to get the bushings out, then used a bench vise to insert the DIFtech pieces.
Honestly, if I wasn't converting from SSC, I probably would have seen where the stock arms put my alignment. |
#186 | |
Drives: '15 STX
#187 |
Drives: Many
I have racer-x but my bushings weren't happy so I bought DIF bushings and had my buddy just build me some cups for them that thread into the racer-x arms.
Way more complicated solution haha. |
#188 | |
Local machine shop could probably do it for the same or less, but he knows the car stuff so it'd probably be right the first time. |
#189 |
Drives: Many
Yeah, that makes sense. I just went about it the other way.
Similar result. |
| The Following User Says Thank You to e1_griego For This Useful Post: | strat61caster (05-14-2020) |
#190 |
Drives: 15BRZ
re: returned to stock
Hey Guys, i finally decided to return the car to stock. Have fun this year in STX!!!
#191 |
Drives: 2017 Asphalt 6spd 86
How do you get to -2 camber on the rear with stock lca?
Is it just from being lowered? |
#192 |
I hit cones.
Drives: 2015 FRS
#193 |
A guy local to me is selling Tarmac 2s, I'm more than likely going to buy them. Does anyone have any experience with them? How hard is the rebound adjuster to reach while in grid, etc?
#194 | |
Compression adjuster on bottom, not too much trouble to reach if you don't mind getting on the ground. - Andrew |
#195 |
Drives: 2017 BRZ series.yellow
Just got finished doing the 'base' build on my first STX twin. First event is this weekend. See how she feels and make adjustments.
Intial setup: 2017 PP BRZ RCE T2's Vorslag camber plates Hotchkiss front bar, 1" hollow on soft with end links Verus rear LCA's 949 6UL 17x9 +40 wheels 255/40 A052s UEL header with OFT HKS Hi-power catback Corner balanced to near 50% cross weight Alignment: Front, -3.9 camber, 0.0 toe Rear, -2.5 camber, 0.40 total toe Any thoughts/advice? Last edited by Breezio; 07-05-2020 at 09:38 PM. |
| The Following User Says Thank You to Breezio For This Useful Post: | Racecomp Engineering (07-08-2020) |
#196 | |
Drives: 2017 BRZ w/PP
how do those fit up front? also did you get custom 6ul because the offset is +40? I only have -3.1* front and at full lock my tire BARELY touches the liner |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 03:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 12:27 PM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 12:30 PM |
| Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 11:05 PM |
