Old 12-13-2019, 06:32 AM   #43
tomm.brz
Drives: brz 2017 hksv2
Again, without logs you can only trust and follow your tuner, as we Don t know what s happening
The Following User Says Thank You to tomm.brz For This Useful Post:
CSG Mike (12-13-2019)
Old 12-13-2019, 08:33 AM   #44
Joe85C
True I dont doubt anything hes saying or question anything hes telling me. I trust him 100% (which is why I've been sticking with him through this entire process). I wanted more opinions about this since this wasnt a problem that started out small and progressively got worse. But instead in less then 2 minutes went from perfect to a completely different car with issues. Will keep this post updated and thanks for all the replies and help. Much much appreciated
Sent from my SM-G965U using Tapatalk
Joe85C is offline   Reply With Quote
The Following User Says Thank You to Joe85C For This Useful Post:
Lantanafrs2 (12-13-2019)
Old 12-13-2019, 08:27 PM   #45
The log is what will solidify my opinion. Get me a log. Otherwise we only have hearsay and are speculating.
Old 02-25-2020, 09:23 AM   #46
Joe85C
Originally Posted by solidsnake11 View Post
Any updates?
Sorry for the extremely late update.... many things happened that put my car on hold. But I do have a solid update. Tuner and a few shops said the same things and were 100% it was not the tune. Instead pointed it towards gears/actuators need to be replaced according to my symptoms. Like stated before quote was around 2k to only fix. So for a little more then 2k I picked up a 2016 motor with 27.5k miles along with a new transmission for very cheap (old motor had 89k miles). Had my tuner install the motor and trans. He retuned it on 91 so that way he can have a better foundation to work with. And what do you know the car is 100% acting the same. The kicker here too and an important factor is that the motor I picked and put in was already previously tuned by my tuner on 91... so the motor was running fine according to my tuner and the seller before purchasing the motor. But I will say the car feels much quicker and stronger when doing pulls. But same symptoms exactly are happening. Nothing had changed except for the car feeling quicker even just on 91. Mpg starts dropping at idle, throttle hesitation is strong under 4k, when to much gas is given after shifting to next gear the car hiccups and same thing happens when I give it quick throttle at low rpms. I highly doubt I picked up another motor that had the exact same issue as mine and is also running 100% the same. Although im bothered the issue isnt fixed I defeinty feel like this motor feel quite a bit more powerful and happy about that. So I'm a little lost at this point. Motor was tuned for 91 previously before I purchased it by the same tuner, then when dropped in my car, the car acts 100% the same with exception of feeling stronger under wot.
Old 02-25-2020, 09:38 AM   #47
tomm.brz
with those money you could have an ecutek kit, e85 flex kit and a perfect tune, and at least you could log and share here instead of trusting sketchy people who don't even know this car
Switching from OFT to Ecutek stlgrym3 Software Tuning 17 08-20-2018 06:39 PM
ecutek racerom map switching trevorthepanda Software Tuning 7 06-25-2018 10:17 PM
EcuTeK RaceROM Map Switching - Restore Last Map on Startup Trick (VIDEO) DeliciousTuning Software Tuning 10 06-16-2014 07:23 AM
EcuTek map switching with OFT? andrew5826 Software Tuning 25 05-10-2014 04:23 PM
ecutek map switching defroster ft86me Software Tuning 8 08-04-2013 03:09 PM
