86WORX
Old 11-25-2019, 11:21 AM   #15
toast
Drives: 14 BSP Edelbrock BRZ
I second this. I'm running 245 and it doesn't feel light and quick like it did stock but I didn't want to run staggered and even with the 245's I can light up third gear (FI).
toast is offline   Reply With Quote
Old 11-25-2019, 12:02 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Are you turbo or supercharged? What kind of tires? Even with 300WHP turbo I'm hooking 2nd and 3rd with Falken Azenis in 215s.
Old 11-25-2019, 12:33 PM   #17
steverife
Drives: 2016 Scion FRS
Like others said, the wider tire will make the car feel heavier and numb on the street.
However, when you push on the car a bit, it will pay dividends (if you've chosen your parts well).
...and all this is assuming everything is tight and aligned properly.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
strat61caster (11-25-2019)
Old 11-25-2019, 01:38 PM   #18
toast
Supercharged. I have Hankook V12s and if it is below 50 degrees second gear just spins. They may be a little harder than the Falkens, but I can't imagine second gear grip with 215s.
Old 11-25-2019, 01:47 PM   #19
i8ur911
Drives: 17 BRZ Series.Yellow
I think "below 50 degrees" is the key part of that statement.
Also, if the wheel is turned at all, it'll be much easier to light up the tires as well versus trying to go straight.
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
DarkPira7e (11-25-2019)
Old 11-25-2019, 01:53 PM   #20
DarkPira7e
DarkPira7e's Avatar
It's all in the compound and application. Once the Falkens get warm, they hold on like a bastard. You won't grip anything on cold pavement, so there's nothing you can do there. You'd also be surprised how big a difference tread block design and block size change grip behavior in tandem with the compound
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
i8ur911 (11-25-2019), why? (11-26-2019)
Old 11-25-2019, 02:23 PM   #21
steverife
It is weird seeing someone praise the Falkens, especially for how they put down power.
Old 11-25-2019, 02:44 PM   #22
DarkPira7e
DarkPira7e's Avatar
They're not without their faults. The get greasy when heated for prolonged use like autocross or hillclimb
Old 11-25-2019, 02:49 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What spring rate?
Old 11-25-2019, 05:58 PM   #24
csol
Originally Posted by gpvecchi View Post
Why people use absurdly wide tires on a 200 hp car?
I'd appreciate if you didnt jump to conclusions on another topic we aren't talking about. Its boosted fyi
Running FI turbo 200kw+ i think it might have something to do with the suspension being soft as I made it stiffer by turning the knob at the top of the structs on the front and back clockwise to the stiffest setting and now it's a tiny bit better
Originally Posted by churchx View Post
Offset is not that much off, scrub radius/steering heaviness should be similar. 255/35/18. Diameter variance is not that different, so acceleration shouldn't be much worse. Wheel weight similar to stock. Tire width within normal range of wheel width. Wheel/tire switch shouldn't change alignment. Who knows the reason but i bought this car for handling, and experiences like these makes me happy to not have turned to dark side of stance/flushness
That aside, if you mentioned "I got hardrace rear lower control arms and custom coilovers with camber plates." - i slightly guess that you installed these alongside wheel/tire change (for clearance/not rubbing/flushness thingies?). If you mod something in suspension, or even simply unbolt/retighten it's parts - definitely redo alignment. Unlike basic wheel switch, suspension changes will make alignment out of whack, and it can change car handling to wrong one. In this case, i guess that there might be some front toe-in gained or alike. I'd also check if those "custom coilovers" are not dialed too soft.
Yeah the shop aligned the wheels they told me and did a re-torque on all the suspension I asked them what my spring rate is they put on but it feels a lot better after setting the softness to stiff.
csol is offline   Reply With Quote
The Following User Says Thank You to csol For This Useful Post:
Old 11-25-2019, 11:17 PM   #25
churchx
churchx's Avatar
Drives: 2014 GT86
csol: in future i advise to whenever you do alignment, to ask for printout of it. Only knowing camber/toe numbers others may suggest with more certainty, if certain handling issue is from that or not. Also knowing what alignment before, simplifies doing planned changes to handling from different alignment. Printout also adds some extra QA to suspension shop work .
The Following 4 Users Say Thank You to churchx For This Useful Post:
csol (11-26-2019), Racecomp Engineering (11-26-2019), why? (11-26-2019), wparsons (11-25-2019)
Old 11-26-2019, 09:12 AM   #26
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
18's are boat anchors. That is what happens.
Grip is compound dependant, not size dependant. Unless you are racing, it's silly to use such large tires and wheels.
The Following User Says Thank You to why? For This Useful Post:
Tcoat (11-26-2019)
Old 11-26-2019, 10:50 AM   #27
18s aren't always boat anchors. Some are reasonably light and it's not too hard to find an 18x8 lighter than stock. But I do think too many people go to 18x9.5s on this car (may not be the issue here).
Either way for this case, you've got to get your alignment numbers and should know your spring rates as well. Hard to help without that.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
DarkPira7e (11-26-2019), strat61caster (11-26-2019), wparsons (11-26-2019)
Old 11-26-2019, 01:04 PM   #28
strat61caster
strat61caster's Avatar
OP did put 18x9.5's on
ineedyourdiddly
Search this Thread:
Advanced Search
2013s less responsive than 2017s? 370zBRZ BRZ First-Gen (2012+) -- General Topics 25 07-28-2018 06:24 PM
Car feels a little less peppy Riftur Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 04-15-2018 07:02 AM
Which entry level turbo kit is the most responsive? Keenercarguy Forced Induction 54 04-18-2017 04:40 AM
Am I the only one that feels bothered by this (R.S 1.0) 1GiantTurtle Scion FR-S / Toyota 86 GT86 General Forum 22 12-11-2014 09:18 PM
18's or 19's ... What looks and feels best on FR-S. Jon1084 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 65 07-19-2013 07:42 PM
