#29 | |
- Andrew |
#30 |
Drives: FR-S Whiteout
Here's someone who stuffed a bilstein piston into his BC shock. Problem with his build tho, he did not degass the oil nor did he give enough consideration to the dividing piston position or gas pressure. He used compressed air to charge his shocks not nitrogen gas. That aside, the response of the adjustment is similar but the extra number of detent clicks give you a bit more fine tuning flexibility.
Sorry about the link beforehand, that forum doesnt work quite as nicely. Edit: effective change of damping pressure from -0 to -20, from -21 o -30 click, little to no change. Based on this dyno compared to the PSS10 linked previously with only effective change in damping pressure at +9(stiffest) to +5 click, so you only have 4 settings that has a notable change in pressures, whereas with te BC adjustments you have 20 clicks to work with out of 30. Also, the damping profile digressive/digressive compared to the COB enabled PSS10 with a digressive/linear valving. If the Pss10 had as much total damping pressure, the difference between the setting "clicks" will be even larger on he PSS10 ![]() Original damper response before revalving for reference:
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 04-06-2020 at 07:20 PM. |
#31 | |
Suspension systems for a road car are all about compromise. The more specialized the car gets (for auto-x, the track, or sweet ass rally jumps)...the fewer compromises you want to make. Just one specific part of that in how it relates to a progressive spring would be shock valving. How do you spec rebound damping? Do you set up your valving around the stiffer spring rate or the softer rate? What will the effect be during body roll motions, hard braking, or big bumps? If you're using less sticky tires and you don't need stiffer spring rates, you can be conservative and it'll be good. But that changes as the car gets more focused. Hope that helps. EDIT: Again, not saying that progressive spring = bad. Just that it's better in some applications, and not as good as the car gets more track focused (or at least more complicated). - Andrew Last edited by Racecomp Engineering; 04-06-2020 at 12:26 PM. |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | solidONE (04-06-2020) |
#32 |
Drives: 2023 BRZ
Thanks, Andrew. My car is definitely a compromise. I go skiing with it (Colorado) 20+ days annually, take it on 2,000 mile road trips, and compete with it. While I have driven coilovers on the track with stiffer, linear-rate springs, I haven't found them to really be any faster. Granted, I'm not on R7s, A7s, R1s, or R1Ses, either. Normally I'm on SX2s or RC1s. Maybe a better driver would be able to appreciate linear-rate springs in the rear more than me, but given the rest of the hardware package I'm working with, I doubt it would make much of a difference. I believe the spring ratios between front and rear have a WAY bigger impact on lap times. WAY bigger. Getting the car to rotate like you want matters a lot. There's no way I'd know the rears aren't linear if someone didn't tell me. And I don't think my car is unpredictable in the slightest. Quite the opposite, in fact.
Director of Rocky Mountain 86CUP
| The Following 4 Users Say Thank You to Pat For This Useful Post: | EB86 (04-05-2021), Racecomp Engineering (04-06-2020), solidONE (04-06-2020), strat61caster (04-05-2021) |
#33 |
Sometimes, I want to move to Colorado. Denver's been exploding the past couple years. I wanna snowboard 20 days a year too lol
Intent > Content
cowardice is the mother of cruelty. |
#34 |
Bilstein adjuster is constrained to the shaft since it adjusts a bleed valve on the piston. They couldn't move it to the bottom without building an inverted damper body for the rear adding weight and cost. KW compression adjuster controls the valve on the damper body that meters fluid to the external fluid reservoir on the twin tube damper so it's always opposite the damper shaft and with a non-inverted front strut design means it's consistently on the bottom of their dampers.
Here's some info on the KW's https://robrobinette.com/S2000KWV3.htm |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | EB86 (04-23-2021), Ohio Enthusiast (04-04-2021) |
#35 |
Drives: GT86
thanks for the info Strat61caster, would you say its only possible on a mono tube to have it on the lower part if its inverted , but if its twin tube its likely? I kind of got the impression from Bilstein that they don't make many like the 86 design anymore at the rear.
Just a quick question - do people set the rear harder than the front on 1 way coilovers generally on the 86 based on its weight balance? Last edited by EB86; 04-05-2021 at 04:27 AM. |
#36 |
Drives: Toyota 86
I’m curious if anyone here has tried these B16 or B14 converted with linear springs...it should be relatively easy using Kw hardware like main springs, helpers and upper mounts (v3 or Clubsport if using Kw camber plates)...does anyone know how much spring rate these Bilsteins could tolerate without revalving? Maybe up to 6 or 7kg?
#37 |
Drives: 2023 BRZ
Vorshlag has done this, and provides it as a service. I have no first-hand experience. If I were to start from scratch on suspension, this is something I would seriously consider.
| The Following User Says Thank You to Pat For This Useful Post: | strat61caster (04-05-2021) |
#38 | ||
As far as I'm aware nobody makes an inverted damper for the rear of the 86, and that's true for most double wishbone/multi-link suspension designs. Quote:
Racecomp has done it too iirc, there's a few posts floating around here. I wouldn't mess around with the KW camber plates, I had a bad failure on another platform with their design, if you can import Raceseng camber plates affordably that would be ideal imho. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | EB86 (04-05-2021), marco_mc22 (04-05-2021) |
#39 | |
Drives: Toyota 86
#40 |
Drives: 2023 BRZ
No need to guess. Talk to Vorshlag.
#41 | |
Since you can only adjust the spring perch, travel will be dictated by where you set the height of the car and your spring rate, it's an odd physics problem to think about but if you are ok with the car sitting up high you should be fine. Set the springs to zero preload (just captured by the spring perch and top hat, slightly loose but no up+down movement) and adjust from there in my opinion. Calling or emailing vorshlag would be a good idea, they have more experience then I do tuning this system but being in italy I understand that may be difficult. Last edited by strat61caster; 04-05-2021 at 07:53 PM. |
| The Following User Says Thank You to strat61caster For This Useful Post: | marco_mc22 (04-05-2021) |
| Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 12:22 PM |
| STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 01:50 PM |
| Bilstein B6s and B8s | speargunsandracecars | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 61 | 05-09-2014 09:04 PM |
| Bilstein I-RC | C3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-16-2013 12:45 PM |
| bilstein PSS | mokinbird87 | Southern California | 1 | 10-29-2013 11:12 PM |
