| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Steering wheel locked car won’t start
my steering wheel is locked and wont unlock and my car wont start.
Every thing works inside and out of the car no fuses or relays are bad the starter,battery and key fob all work fine but the car still won’t even attempt to start just goes right to accessory, and I can hear the fuel pump turn on does anyone know what would cause this or how to fix it? It’s been at a dealer for a week and they dint know what’s wrong with it or how to fix it and are waiting in Subaru tech support to figure it out |
#2 | |
The Dictater
Drives: '13 Red Scion FRS
It’s a push button cause it’s a brz but yes if I push the button it goes to accessory and won’t attempt to turn over and the wheel will not unlock no matter what I do and the dealer can’t unlock it either
| The Following User Says Thank You to zakman16 For This Useful Post: | Spuds (11-11-2019) |
Drives: 4wd zooks
Did you try the spare key fob? Auto or manual car?
They can do weird things when the fob battery is weak! The safety switch on the manual clutch pedal? |
| The Following User Says Thank You to alan.chalkley For This Useful Post: | Spuds (11-11-2019) |
Rust bucket enthusiast
I'm suspecting weak fob battery of clutch pedal switch.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Spuds (11-11-2019) |
Drives: 4wd zooks
Use a multimeter to double check the clutch safety switch and the attached wiring.
Also use a multimeter to check every fuse in the car. And make sure the new fob battery is good and is seated properly. |
| The Following User Says Thank You to alan.chalkley For This Useful Post: | BirdTRD (11-14-2019) |
Drives: Subaru BRZ
WTF, you have to insert a key into an ignition to start the car.. what are you driving? Something from the 80's??
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Also make sure you also check the 2 in the fuse block assembly at the + battery post.
| The Following User Says Thank You to BirdTRD For This Useful Post: | alan.chalkley (11-14-2019) |
#10 |
Purist
Drives: 2013 FRS - Hot Lava
Pull the tension out of the steering lock!
NVM, didnt read. Happens all the time though.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#11 |
I visually checked all the fuses and relays and switches some around with ones that were similar I didn’t use a multi meter tho. And The dealer said there were fault codes linked to the ecu and it not communicating properly so I got a used ecu of a guy parting out 13 brz manual like mine and I’m having them recalibrate it to my car, hopefully this is the issue
**quick update changed out the ecu still doesnt start... Last edited by zakman16; 11-15-2019 at 04:09 PM. |
#12 |
If the steering wheel isn't unlocking, it sounds like an immobilizer issue?
Was the new ECU programmed to work with your cluster and key?
#13 |
yes it was, both keys also work fine and the dealer programmed the ecu them self, if the immobilizer was the issue how would i know/ is there a way to bypass it to get the car to start?
#14 |
If there was it would totally suck as an immobilizer.
| Tags |
| wheel locked, won’t start |
| Blue carbon steering wheel and steering wheel trim... installed! | Pointmutation | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 02-07-2017 12:20 AM |
| Steering wheel locked Towed to dealer | kmac_brz | Issues | Warranty | Recalls / TSB | 81 | 11-17-2015 03:33 PM |
| FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal | mtsui | Interior Parts (Incl. Lighting) | 5 | 08-11-2015 01:15 AM |
| Steering wheel locked no start | kmac_brz | Issues | Warranty | Recalls / TSB | 1 | 07-08-2015 11:35 PM |
| When doors are locked manually the car won't start | whataboutbob | Electronics | Audio | NAV | Infotainment | 9 | 10-14-2012 12:10 PM |
