Old 11-10-2019, 10:30 PM   #1
pillbox
Drives: ZC6
Greddy T518Z Strange Ticking Noise
Hey all, I just recently installed a brand new Greddy T518z turbo kit. I took my sweet time to make sure everything was mechanically sound.
There is a loud ticking noise that can be heard when the car is accelerating under load. The ticking speeds up as the engine speed increases. It becomes hard to hear as the engine speed is above 3.5k since the turbo and engine sound overwhelms it. I thought it was an exhaust leak, but both a shop and I couldn't find any leaks in the exhaust system.
I've read a ton of threads and most of them seem to have found the header gasket leaking. I've visually inspected the gaskets without taking the exhaust manifold off, and no soot building is found anywhere, on any exhaust flanges for that matter. I'm wondering if anyone has any suggestions?
[ame]https://www.youtube.com/watch?v=FvapnUI-TUg[/ame]
[ame]https://www.youtube.com/watch?v=aD8zHj7WuwM[/ame]
2015 Subaru ZC6 BRZ
SPC Front Camber Bolts - PMU Club Racer Advance - GT Radial Champrio SX2 215/45/17 - HKS Type-S Oil Cooler - Verus Engineering Fuel Starvation Door
pillbox is offline   Reply With Quote
Old 11-11-2019, 07:20 AM   #2
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
Does it happen while not in gear? For example being in neutral and just climbing the revs?
OzzyGT86 is offline   Reply With Quote
Old 11-11-2019, 10:21 AM   #3
mwiech
I had the same exact ticking noise and it drove me crazy trying to figure it out. I only noticed it after going FI. Turns out it was the stock injectors and fuel pump. Once I got those upgraded the noise went away completely. If you already have upgraded injectors/fuel pump then I don’t know.
mwiech is offline   Reply With Quote
Old 11-13-2019, 12:51 AM   #4
pillbox
Drives: ZC6
I'm able to get it to happen when in neutral but only with a lot of throttle application. Typically, I can hear it during heel-toe.
That's really weird, I wonder why going FI creates this sound, because I definitely didn't hear it when NA! I'm still on stock injectors and pump.
2015 Subaru ZC6 BRZ
Greddy T518Z Whp j_ros94 Forced Induction 64 08-09-2020 12:35 AM
GReddy T518Z Turbo Kit Richytort Engine, Exhaust, Bolt-Ons 4 09-01-2017 02:39 AM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 03:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 07:09 PM
