| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
Drives: '13 BRZ TLM Spec
This
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
#44 | |
#45 |
So to help with the Sunload sensor...has the dash ever been out of the car, say for replacement or some sort of repair? If so it is very possible the sunload sensor was unplugged and never plugged back in. That is where I would start first.
To help with the key reprogramming...I have yet to find a locksmith that can program a new key to work with the immobilizer, they can only program the lock/unlock features to the fob. That can only be done with the Subaru Select Monitor-SSM (Dealer scan tool). The Techstream WILL NOT program keys on BRZ's and the Subaru Select Monitor (SSM) WILL NOT program keys on a FR-S/86. Techstream can be used to pull codes, read some data, etc on the BRZ, but isn't as thorough as what the SSM can do. I use the ECUtek reader more often than the Techstream...and then the SSM for everything else. If a Subaru dealer is using the SSM and telling you they cannot access the ECU it is likely 1 of 2 things: 1: The ECUtek flash is disrupting the connection 2: The OBD2 port in the car is flakey (easy fix is to use a cheap OBD2 extension cable between the device and the OBD2 port. I bought a cheap one from Amazon to "fix" this issue on my BRZ.
#46 | |
Drives: 2013 Subaru BRZ
Yes my dash was opened a few years ago I put some carbon fiber in. But this sunload sensor only showed up a few months ago so I don't think this is the case.
Anyways I've been in contact with Mike at Xero-Limit who did my tune. He thinks my Ecutek dongle is faulty. When I connect my ecutek dongle to the OBD2 port it shows as green. When i connect to my labtop and the license usb they both show as connected. I updated the ecutek software and drivers. But the 'detect' vehicle option is grayed out. I went to choose Subaru BRZ manually, and i get an error "No CAN Vehicle Interface was found". I tried different usb ports, and a different labtop. Same error. So at this point i think it's the ecutek dongle or a faulty OBD2 port, or both. Quote:
| The Following User Says Thank You to morswestford For This Useful Post: | Opie (10-31-2019) |
#47 |
I would still check to be sure the sunload sensor is plugged in all the way. There isn't a whole lot to go wrong with one, it's either faulty or not plugged in...or something is interrupting the signal to the ECM.
#48 |
The Subaru dealership was finally able to fix my keyfob (program it) and clear the check engine code. They had to replace the ECM to do it.
Once I flash the car's tune with my Ecutek tuke, my keyfob will still be programmed to the vehicle, however if I ever need anything else from Subaru in the future. They will never be able to read the vehicle. The lead tech at the dealership said Ecutek is blocking their scan software (and i assume all Subaru dealerships are using) called Select Monitor 3. Tech suggested I use a different software. He recommended Cobb which doesn't block their scan tools but I don't believe there are any ones specifically for the BRZ, I've only seen Ecutek. So now I will go back to the dealership next week, flash my car back to my Ecutek tune (once I get an updated license because I now have a new ECM) to get things back to normal. But if I ever need a keyfob again, I will have to spend another $1k on parts and labor for them to do that. Also i can only check CEL codes through Ecuteks tool and never the dealerships since they are not able to read the car once I flash it. Isn't that unbelievable? P.S. OBD2 port was just fine as they obviously were able to read the vehicle just fine once they installed new ECM. |
| The Following User Says Thank You to morswestford For This Useful Post: | Lantanafrs2 (12-07-2019) |
#49 |
Drives: 2013 frs red
The joys of owning a modded car
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Tcoat (12-10-2019) |
#51 |
#52 |
Drives: 2013 FRS pearl White
I believe there is something faulty in the ECM/ECU's in theses cars. Mine (totally stock) has been throwing codes and CEL light for a couple months (it pops up along with the traction control light), usually it says it is an injector issue, or that the system can't communicate with the CANBus.
I've had it to a private Subie shop several times and after checking all the connections, the tech can't find the issue anywhere. His reader says teh same thing. We thought it might be varying voltages from teh alternator, or a bad battery. I replaced the battery and the Alt checked out ok. Then suddenly the CEL went off. Drove a couple months, and it came back. Went out on its own, then came back. My guess is the ECM/ECU is faulty, but it is a pricey fix. |
| Tags |
| brz, ecu |
| Tuners like "Mugen" or "Spoon" for Subaru? | Seiryuu | BRZ First-Gen (2012+) -- General Topics | 21 | 09-08-2018 04:33 PM |
| dealership thats willing to fix timing cover leak for "heavily modified" brz | iarefluffy | Southern California | 14 | 12-29-2017 12:53 AM |
| Will the dealership "ECU Flash" be reset to factory after disconnecting battery? | spatcha88 | Engine, Exhaust, Transmission | 5 | 04-02-2015 03:35 AM |
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 11:17 PM |
| Collection of "Subaru axing BRZ" & "Subaru making next-gen BRZ" rumor threads... | mav1178 | Other Vehicles & General Automotive Discussions | 42 | 07-07-2014 04:52 PM |
