10-02-2019, 11:26 PM | #1 |
Drives: anything you let me
JDM Engine Swap...
Ok, let me get the first part out of the way because someone is bound to say 'just get your motor rebuilt' as happened in the other thread on this subject that I didn't want to hijack. I am sending my motor to Element to be rebuilt, that's already in the works. Good, that's out of everyone's systems.
So long story short, and to quote Long Duk Dong, 'Lake... big lake...'. My stock motor is toast. As you can imagine, there is some significant lead time (about 3 months) to have it rebuilt properly. I don't mind waiting for quality. To get my car up and running quickly so it is usable until the new motor is ready, I have the opportunity to get a low mileage pre-'17 Japanese 86 motor (with transmission and all the trimmings) for an exceptional price. My thought process is, even when the new race engine goes in, the JDM one will become a backup engine likewise the transmission, alternator, coil packs, etc. because you just never know. Now here's the question and hopefully someone has tried this successfully before... Obviously I'll have to keep my stock ECU and harness which is fine, but is there any reason a RHD car motor will not be a direct drop-in? Is the exhaust routed differently because of the steering column, connectors in a weird spot because of the clutch cylinder on the other side of the firewall, etc. Anything anyone could chime in about would be greatly appreciated. Thanks in advance guys! |
10-03-2019, 08:39 AM | #2 |
I'm not sure why all of these stock engine swaps are in the engine swap thread. This is not the correct area. Your question should be in the engine/trans area.
The Following 3 Users Say Thank You to all4spl For This Useful Post: |
10-03-2019, 08:42 AM | #3 |
Rust bucket enthusiast
@ichitaka05 I wonder if we should change the title of this sub-forum to "Engine Swap (Non FA20)"?
Uplink, I'm fairly sure there are several reasons why it won't swap into your 2014, which have been covered in a variety of other threads. It's not impossible, but it's a hell of a lot of trouble when you can just get an engine for your model year and be ok. I apologize that I can't recall specifically what changes were made, but they're significant enough to know that they won't be worth it for you. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | Uplink (10-03-2019) |
10-03-2019, 09:31 AM | #4 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Uplink (10-03-2019) |
10-03-2019, 09:46 AM | #5 | |
10-03-2019, 10:35 AM | #6 |
Drives: 2013 Ultramarine FR-S
He mentioned it being Pre-'17. So should be compatible if JDM engine are indeed the same
The Following User Says Thank You to DustinS For This Useful Post: | Uplink (10-03-2019) |
10-03-2019, 03:28 PM | #7 |
Sorry about that. I kinda flipped a coin on which to post in since it was technically about changing the engine. We can move it to the other group.
10-03-2019, 03:29 PM | #8 |
10-03-2019, 03:39 PM | #9 | |
I've got a 2015 FR-s and the motor is a pre-2017 JDM 86 not the newer Toyota GT 86 (still has the old style intake manifold). There's definitely issues like the ECU not functioning properly and the immobilizer which is why I'd keep those from my existing setup. I had trouble finding any mechanical reasons why this wouldn't work like location of sensors and brackets. I can use my factory or HKS exhaust manifold so as long as that mates up properly to the block, plumbing shouldn't be a problem, the exhaust should be just like stock. No worries, thanks! |
10-03-2019, 03:52 PM | #10 | |
If we're right about the long block being the long block being the long block... the immediate concerns would be exhaust plumbing (not an issue if a LHD exhaust manifold is direct bolt-on), the location of sensors that may not reach with my harness (not sure if this engine has any optional ports), and interference items in the bay (brake booster, clutch master, etc.). I'm pretty sure the noise tube (closest thing to the brake/clutch assemblies) routes the same way on both spec cars but I don't have mine installed so that's moot. Thanks for your help with this! |
10-03-2019, 04:09 PM | #11 | |
Wanted to get ahead of this all because I went through similar issues when I swapped my L98 Vette motor (PS dipstick) with an older (DS dipstick) block. Granted that was not exactly like for like and in the end it worked but there were enough headaches and workarounds that I would have raised an objection to the project early on. Thanks! |
10-03-2019, 04:11 PM | #12 |
@ichitaka05 Could you move this to the normal engine group? I mis-understood the topic title.
Thanks! |
10-03-2019, 05:08 PM | #13 |
Ya I wasn't referencing that HIS was a post 17 swap just that the swap of a post 17 (what are the terms the kids use for the two models? Gumby and Poky or something like that?) would probably be more difficult than a JDM.
Similar Threads | ||||
Engine Swap | Riftur | Engine Swaps | 2 | 07-21-2017 04:20 PM |
2JZ engine swap? | s_king20 | Engine Swaps | 8 | 12-10-2015 03:09 PM |
Engine swap JDM EJ25 STI engine | FRSToyota86 | Engine Swaps | 25 | 11-20-2013 01:56 AM |
Engine Swap | hybrid35 | Southern California | 0 | 01-07-2013 01:04 PM |
Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 03:58 AM |
