Drives: 2013 Asphalt FR-S
OEM Forester Oil Cooler - Coolant Hose Question
Hello,
I searched for a while but couldn’t find it. I have the cooler And the stem already. What hoses do I need to run the FORESTER OEM oil cooler/heater? I’m planning on running lines through the Coolant feed below the throttle body. I see that on the cooler itself, there is one barb for a 1/2 ID, and the other for 3/8 ID. But would 1/2 in fit up on the engine itself? Any help would be appreciated. Thank you! Edit: kinda found the answer. Kits are running 3/8 for both nipples. Need to squeeze the 3/8 one over the 1/2 barb. AND then, the TB in/outlets are smaller than 3/8. GFG. Good clamps needed. Last edited by Neurytic; 09-12-2019 at 01:36 AM. Reason: Found answer sorta. Confirmation anyone? |
| FS: NJ/NYC OEM (Forester) oil cooler/oil cooler connector | Joon525 | Engine, Exhaust, Bolt-Ons | 3 | 09-20-2019 06:00 PM |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 06:28 AM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| FS: used forester oem diy oil cooler | cruizin01 | Engine, Exhaust, Bolt-Ons | 2 | 01-05-2015 05:12 AM |
