86WORX
Old 11-14-2019, 09:34 AM   #113
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Oh, and 221hp intake guy.
The one made of painters tape, cardboard, and scrap aluminum?
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following 3 Users Say Thank You to yelsew For This Useful Post:
humfrz (11-14-2019), KR-S (11-16-2019), soundman98 (11-16-2019)
Old 11-14-2019, 10:30 AM   #114
KR-S (11-17-2019), yelsew (12-12-2019)
Old 11-14-2019, 12:28 PM   #115
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by 86MLR View Post
In other news, less pointless though
S660??
Not sure if I should ban the op or not cause i dont know if this thread is serious.
You know this is not the only thread he has done on this
Old 11-14-2019, 01:13 PM   #116
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by GrantedTaken View Post
I replaced my front pads this weekend. blah blah blah piss moan troll
Who cares.
Worst backyard mechanic ever.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Ultramaroon (11-15-2019)
Old 11-14-2019, 01:44 PM   #117
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
S660??
I LOVE those little Ki cars!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 11-14-2019, 01:55 PM   #118
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
First one I seen in person was in Tokyo in 2012. I want one so bad
Old 11-14-2019, 01:59 PM   #119
StraightOuttaCanadaEh
Wes
I've noticed my right rear brakes squeak whenever it's raining/snowing and/or cold. I first thought maybe it's the pad wear indicator that started squeaking (is there one on this car?) but the car is only at 50K km (~35K miles) and I feel like the pads should last longer than that. I looked at the rotor and there is a single deep groove that's not present on the other 3 rotors. What could this be? Is it a stone lodged in there?
Instagram: @gt86ws
Old 11-14-2019, 02:05 PM   #120
weederr33
weederr33's Avatar
You should be able to peek in there with no problems. Basically every car in a parking lot has that design. But for some reason this one doesn't. I think the squeaking is actually just rust build up. But I don't know how you made your brakes last 50k km. Do you just drive on the highway? Mine only had 2mm left after 10k km.
Old 11-14-2019, 02:06 PM   #121
weederr33
weederr33's Avatar
Same! I saw a Mugen version and fell in love.
NoHaveMSG (11-14-2019)
Old 11-14-2019, 02:46 PM   #122
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
S660??
wrong kei car, that is a 1st gen daihatsu copen
HKz is offline   Reply With Quote
The Following 3 Users Say Thank You to HKz For This Useful Post:
86MLR (11-14-2019), NoHaveMSG (11-14-2019), soundman98 (11-16-2019)
Old 11-14-2019, 03:07 PM   #123
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
That is normal, unless your doing very hard consistent braking your pads are fine. A small amount of rust appears when there is a lot of moisture in the air which can cause a bit of squeaking. You will see once the air dries out and you drive a bit the squeaking will go away. My OEM brake lasted until 80k FYI and over the years it always squeaked a bit after it rains. Also the oem brakes do have a metal bit that is designed to squeal when the pad wears enough.
As for the groove, that is concerning, I would off the pads and inspect it. I'm going to guess the guide pin on the caliper could be gunked up causing abnormal wear on that disc. You can remove the guide pin, clean it up, and add some silicone based grease and re insert it. I think Chris FIx has a great how to video detailing the process.
DandoX is offline   Reply With Quote
The Following 2 Users Say Thank You to DandoX For This Useful Post:
humfrz (11-14-2019), StraightOuttaCanadaEh (11-14-2019)
Old 11-14-2019, 03:15 PM   #124
DandoX
Senior gif poster
DandoX's Avatar
That is some serious braking, sounds like you cooked your brakes which would cause it to overheat and wear out right away. For normal DD the oem brakes last a super long time if there is no auto X or track days. Really the oem brakes don't really do well with auto X or track days that have prolonged hard braking.
For normal DD driving, I brake super hard all the time with no engine braking and mine lasted about 80k. Granted I'm in an area where it isn't as hot and I haven't done auto X or track days.
Old 11-14-2019, 03:31 PM   #125
Wes
For the first 40K or so it was mostly highway, and even when I'm not on the highway, I basically don't brake lol. I use engine braking a lot and I anticipate the flow of traffic and let off the gas strategically so by the time the light turns green, the traffic starts moving and I just set off again without having to touch the brakes
Instagram: @gt86ws
Old 11-14-2019, 03:41 PM   #126
weederr33
weederr33's Avatar
Oh... that was all supposed to be sarcasm.... lol
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
DandoX (11-14-2019), soundman98 (11-16-2019)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 04:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
