Old 09-06-2019, 10:33 PM   #29
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Originally Posted by EndlessAzure View Post
As far as I'm aware, the OE filter threads into uses a M20 x 1.5.
The Greddy plate adapter changes the thread to 3/4"-16 UNF. It is stated on the Greddy website that the oil cooler kit "requires use of QX-1,3, SX-1,3 oil filter," which when identified on their product inventory is a 3/4" threaded filter with 65mm diameter. It looks like "O" part numbers have replaced Q or S. Google searches for inventory QX/SX turn up 3/4" / 65mm as well
http://www.greddy.com/products/ic-oil-rad/oilcooler/
http://www.greddy.com/products/engine/oil-filter/
Good catch.
I wonder what filter the guy in the post I quoted is using? Maybe it's NOT a Subaru filter afterall?
Joon525 is offline   Reply With Quote
Old 09-14-2019, 03:42 PM   #30
Chuckable
Drives: 2017 Toyota 86
Updating the post with some finished pictures.
Chuckable is offline   Reply With Quote
The Following 3 Users Say Thank You to Chuckable For This Useful Post:
CSG Mike (11-01-2019), JBezugs (03-19-2020), SexyPirates (06-19-2021)
Old 09-14-2019, 03:43 PM   #31
Chuckable
The Following User Says Thank You to Chuckable For This Useful Post:
Old 09-14-2019, 03:44 PM   #32
Chuckable
Old 09-14-2019, 03:45 PM   #33
Chuckable
And after some further research, I believe the Fram 2951 will fit. I’ve ordered one and will verify fitment probably sometime next week.
Old 09-14-2019, 06:11 PM   #34
Chuckable
Front bumper cover mostly back on for final shot. Had to remove a trim piece behind the bumper and trim the oil cooler shroud to make it fit behind my 2017 bumper. But otherwise everything fit well.
Old 09-14-2019, 06:13 PM   #35
Chuckable
I contoured this to the shape of the bumper cover, and added some weatherstrip to make a seal.
Old 09-23-2019, 03:45 PM   #36
Chuckable
Greddy Oil Cooler
Can confirm that the FRAM 2951 fits. Gaskets match up as well. The FRAM is about 3” diameter, which is the maximum that will fit.
Old 10-30-2019, 03:34 PM   #37
Chuckable
Greddy Oil Cooler
Realized that I never explained what needed to be trimmed. Here is the section of the shroud that needed trimming to fit behind my 2017 Toyota 86 bumper cover:
And here is a rough representation of the trimming needed:
And here again the a close-up of that section looking through the front bumper cover, with some foam to seal the bumper cover to the shroud:
Old 11-01-2019, 02:56 PM   #38
I think as a gross rule of thumb you want to get the oil to at least 212F during operation to help boil out any water that inevitably gets absorbed into the oil.
That's why a block-off plate is advisable.
Water evaporates out of oil, even at less than 212F. You can see an example of this when you boil water on the stove; you'll see vapors before the water is actually boiling.
Oil temp readings from the 86 are ***post cooler***. Your oil is certainly hot enough pre-cooler!
Grady (11-01-2019), solidsnake11 (11-01-2019)
Old 11-01-2019, 04:20 PM   #39
solidsnake11
Drives: brz
solidsnake11 is offline   Reply With Quote
Old 11-01-2019, 05:01 PM   #40
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Wow, the Greddy cooler with the shroud looks like it's probably more effective than the JR design. Very nice. My JR is keeping up with temps nicely here in Texas, at least NA.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Old 11-01-2019, 05:15 PM   #41
It's 100% worth it if you want or need more cooling. My turbo is oil cooled, and I never see over 225F or so on oil temp.
HachirocksU (11-08-2019)
Old 11-01-2019, 06:47 PM   #42
Tristor
Tristor's Avatar
Yeah, if I go FI in the future it may be worth considering.
Search this Thread:
Advanced Search
Greddy oil cooler to cold mattlang89 Engine, Exhaust, Transmission 5 05-24-2015 01:47 PM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 04:40 AM
Greddy oil cooler coming soon DIG1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 08-20-2012 01:02 AM
Greddy Oil and Diff Cooler pdreams Engine, Exhaust, Transmission 3 06-13-2012 09:41 PM
