Old 09-03-2019, 10:47 PM   #1
Snyperiflex
Snyperiflex's Avatar
Drives: Scion FR-S Release Series 1.0
Fortune Auto 500 w/ air piston lift system
Even though this kit has been out for a few years now, it is difficult to find good information about it online. So here's my initial review.
There is one thread on here from early on in this product's life
https://www.ft86club.com/forums/showthread.php?t=101116
and although there were issues, I decided to give this kit a chance as Fortune Auto has had 3.5 years since to continue improving the package.
I placed my order through Fortune Auto directly, and although there was a free shipping promo, I was only allowed to apply it to one box (this kit comes in 2 boxes). I ended up paying a little over $3000.
This came with FA500's in my spring rate spec and air cups (front only).
Initial impressions were mixed:
The coilovers and air cups look great they were also already set for some spring 'droop' to get the max range of lift. I have no issue getting the car to sit at the height I want. Love the coilovers, no complaints.
The air system components are okay (tank legs were welded on but their alignment is off) All wiring and fittings came pre-installed.
The wire to the battery was only about 3 feet long, and ground cable only about 6 inches long. The kit did not come with any more wire nor any connectors or taps.
I also wish the instructions were more thorough other than a single diagram.
After purchasing 100ft of 12 gauge wiring, Posi-lock + Posi-tap connectors, and braided cable cover, I installed the kit.
I tapped the 12v in the glovebox for ignition, the battery for power, and one of the grounds in the passenger footwell.
From the thread I posted above, that user also complained that there was not enough wire to run to the battery.
The kit has also gotten more expensive ($400+) and comes with 2 less cups (no rears) than it did back then.
These are just my initial impressions.
Snyperiflex is offline   Reply With Quote
The Following User Says Thank You to Snyperiflex For This Useful Post:
soundman98 (09-03-2019)
Old 09-03-2019, 11:35 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
their wiring diagram is crap. i looked, attempting to shed some light on it for you.. if you were local, i'd take a look at it some time.
per their diagram, the ignition goes through the pressure switch, the relay somehow gets 3 constant power wires(no terminal designations mean this information is less than useless), and the air up/down are air-only actuators(should be solenoids). none of which i know should be true.
Snyperiflex (09-04-2019)
Old 09-04-2019, 03:56 AM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm sure you'll get it working in the end, even if it means shipping things back and forth a couple of times. FA isn't exactly Penske.
aircup, coilovers, fortune auto, install, suspension
Fortune Auto Air Piston Lift System Bluehwy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 01-07-2019 06:38 PM
Air Lift Performance AutoPilot V2 Digital Air Management System for BRZ GT86 FRS aaguirre123 Brakes, Suspension, Chassis 4 12-28-2016 09:37 PM
*Piston Cup Kit BLACK FRIDAY Special* DSG Edition Fortune Auto 500 Series Coilovers Jason@DSG Brakes, Suspension, Chassis 62 12-03-2015 01:55 PM
Introducing The Fortune Auto Air Piston Lift System Jason@DSG Brakes, Suspension, Chassis 1 11-23-2015 04:02 PM
What Fortune Auto Is All About Jason@DSG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-23-2014 10:23 AM
