Old 03-16-2015, 07:51 AM   #99
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
After getting two gear levers replaced the rattle kept coming back. I've eventually managed to fix it by getting to the root of the problem - the thin washer at the bottom of the gear lever under the car.
You'll see a split pin holding the gear lever to the rod on the gearbox. Remove it together with the thin washer and replace with a thicker steel washer and refit the pin. Problem solved.
( It's the joint right at the bottom of this pic that you're looking for.)
Pics from this thread:
http://www.ft86club.com/forums/showthread.php?t=31340
BTW.
I've sprayed some Liqui Moly Tacky Lube Spray in there as well for good measure.
EDIT:
Special thanks to @Freedom who noticed the loose washer.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
The Following 10 Users Say Thank You to sav For This Useful Post:
akahenry (09-19-2015), clintavo (03-16-2015), DarrenFord (07-24-2015), DocWalt (03-20-2015), Ds3ire (05-19-2015), Fastbrew (06-10-2015), Legend@wheels (12-10-2018), PWBRZ (03-17-2015), Teseo (03-16-2015), Yobiwan (09-01-2016)
Old 09-19-2015, 04:19 AM   #100
akahenry
akahenry's Avatar
Drives: '18 STi
Originally Posted by sav View Post
After getting two gear levers replaced the rattle kept coming back. I've eventually managed to fix it by getting to the root of the problem - the thing washer at the bottom of the gear lever under the car.
Do you know the part number for the washer and pin, or the approximate size and width of the washer?
akahenry is offline   Reply With Quote
Old 09-21-2015, 10:39 AM   #101
sav
sav's Avatar
I don't unfortunately, I just happened to have a washer laying around.
95RON SAV Tuned
Old 09-21-2015, 01:09 PM   #102
kodyo
Drives: Scion FR-S
I tried the washer trick mentioned above with a neoprene washer. There is seriously no space there for another washer (mine was thinner than a dime). Tried for an hour to get it in and then gave up and put it back to stock. Very tight working space too.
kodyo is offline   Reply With Quote
Old 09-24-2015, 09:25 AM   #103
sav
sav's Avatar
Nobody said it was going to be easy.
95RON SAV Tuned
The Following User Says Thank You to sav For This Useful Post:
kodyo (09-24-2015)
Old 09-24-2015, 11:30 PM   #104
kodyo
Drives: Scion FR-S
I actually solved most of the issue by screwing on the shift knob tighter (it's a full metal knob, so it won't bust the top like it may on the stock one). At this point I've just decided to go with "becauseRacecar".
Old 12-18-2016, 07:35 PM   #105
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Also had the noise above 4K in 3rd-5th gears. 2013 car.
The Perrin reverse collar appears to have solved the noise in my case.
One tip: getting the pin back through the hole on the cable terminal is a PITA because the cable terminal is under tension and sits very low. Use a screwdriver or the 3/32 hole punch perrin recommends, to release the cable lock and shift the stick into reverse. the cable is temporarily de-tentioned and then it's much easier to replace the holding pin back through the hole on the cable terminal.
canyons is offline   Reply With Quote
Old 06-18-2017, 08:08 PM   #106
iManage
iManage's Avatar
Drives: '14 Whiteout Pearl
I was having this issue as well, and I finally came up with a really easy fix. It's more expensive by far, but a lot easier, and neither the gear shift knob nor the road noise bothers me anymore.
I installed a 700Watt stereo system. No more issues!
iManage is offline   Reply With Quote
The Following User Says Thank You to iManage For This Useful Post:
MJones_RB (09-01-2021)
Old 08-23-2018, 06:01 PM   #107
BOND007_LTK
Drives: 2013 brz
Size of washer? Part #?
So... anyone know what Size of washer? Part #? Width?
I don't want to take it apart only to find out I don't have the exact dimension needed to fit the washer...
Car would be out of service for a loooong time in that case.
BOND007_LTK is offline   Reply With Quote
Old 12-10-2018, 04:11 AM   #108
Legend@wheels
nenber
BTW.
EDIT:
just might be the solution for that nightmare !!
1 is this approachable from inside the car and not need to do anything under the car ,correct?
2 i can use any steel washer i can find that will fit into there and make it tighter -no genuine is required?
Legend@wheels is offline   Reply With Quote
Old 12-10-2018, 04:27 AM   #109
sav
sav's Avatar
1)No you have to do it from underneath.
2)Any washer that fits is fine, it's a bit tricky finding the right one.
95RON SAV Tuned
Old 12-10-2018, 04:52 AM   #110
Legend@wheels
nenber
Shitty job then.
Dammit
Think its possible from inside the car if i remove all the surrounding parts
Sent from my SM-G960F using Tapatalk
Old 12-10-2018, 05:23 AM   #111
sav
sav's Avatar
It's not that bad from the bottom. Simply lift the car up.
95RON SAV Tuned
Old 12-10-2018, 05:24 AM   #112
Legend@wheels
nenber
Any approach without removing any covers ?
Possible with jack stands or only lift?
Search this Thread:
Advanced Search
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 11:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 11:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 02:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 08:46 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 09:20 PM
