#15 |
Drives: Attitude
Dude, just open the door and jump on the door sill repeatedly.
![]() Actually, strut clearance could change with tire deformation under cornering with compression, no? |
#16 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Bias ply tires will, but not radials. These tires especially not as they actually have steel inserts in the sidewalls.
#17 |
Drives: Attitude
The more you know.
#18 |
Corner Junkie
A couple more cell pics while I'm at work:
| The Following 3 Users Say Thank You to Draco-REX For This Useful Post: |
#19 |
Gundam Meister
Drives: A Gundam
Those wheels are awesome and perfect size. I might have to reconsider these.
#20 |
Corner Junkie
Just gotta do something about that fender gap..
Help me RaceComp Engineering! |
| The Following User Says Thank You to Draco-REX For This Useful Post: | stevo_12v (08-10-2012) |
#21 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
So torn between these and the OZ Ultraleggeras in 17x8 - these are 2 pounds lighter but almost 600$ more for the set. More pictures are needed.
#22 |
Drives: 86 (FR-S)
Fitment looks excellent man! Coils will make it look amazing. Great job!!
| The Following User Says Thank You to Jeff86 For This Useful Post: | Delacruzmd (08-04-2012) |
#23 |
Corner Junkie
I am really liking these wheels. If only I could do hubcentric rings and center caps at the same time.
#24 |
Corner Junkie
Aaaaaand.... needs more low.
#25 |
Drives: 2013 Subaru BRZ
Looks great. It's a bit hard to tell...do the fronts poke a little? The +42 looks pretty perfect on the 8" wheel.
Ok for a wheel newb can you explain the need for hub centric rings...and can you not use both rings and center caps? |
#26 | |
Corner Junkie
Hubcentric rings fit between the wheel and a raised lip around the center of the hub. Using a hubcentric wheel or rings directs forces acting on the wheel to be transferred directly to the hub rather than the lugs. It a stronger way to mount the wheel than just the lugs. As for using rings and caps together, normally you can. But from what I understand, these particular wheels are milled in such a way that it is one or the other, but not both. |
#27 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
DAMNNN!! Nice choice of wheel.. lightweight and GOOD LOOKS.
Here is a guy who has great taste!! ![]() If your after hubcentric rings and caps check out perfectrun.jp ![]() They also carry the AL-type allow racing nuts too(each nut weighs the same as a AA battery)
[CENTER]
Build thread |
#28 |
| Wheel Directory: SSR Competition 17x8.0 +38 | Enigmus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 08-07-2015 07:38 PM |
| WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel | RavSpec | Wheels and Tires | 72 | 12-04-2012 04:58 PM |
| Wheel Directory: Advan RG II 17x8.0 +45 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-11-2012 08:28 PM |
| 17x8 +35, will it rub? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 07-31-2012 04:26 AM |
| Pre Order TC105N | vividracing | Wheels and Tires | 27 | 07-30-2012 04:28 AM |
