#141 | |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#142 |
A twin-charged 4 cylinder sounds like a nightmare to work on.
The days of powerful NA 4cylinder engines are gone. |
#143 | |
Drives: '06 AM V8V Coupe
Guys who race the 2zz on Spyderchat recommend not going over 8000 continuously because the reliability is not so good on the track. Sent from my Redmi 3 using Tapatalk |
#144 | |
I am also okay with them offering an automatic transmission to improve sales, as long as it comes with a stick option. However I would rather they spend money on making a light, strong chassis and good suspension than some fancy turbo engine. I don't understand what is so bad about a naturally aspirated K24 or R18, which would be adequate if they get the curb weight low. Sent from my Redmi 3 using Tapatalk |
| The Following 2 Users Say Thank You to serialk11r For This Useful Post: | funwheeldrive (01-31-2017), WolfpackS2k (01-31-2017) |
#145 |
That's kind of sad. You would expect better of Toyota.
| The Following User Says Thank You to WolfpackS2k For This Useful Post: | daiheadjai (01-31-2017) |
#146 | |
Pretty slick IMO: http://www.s2ki.com/forums/s2000-nat...-2-4l-1161441/
#147 | |
Drives: GTS
I'd be happy with a 1000kg chassis with an R18 engine. They are very good for forced induction (more so than a FA20!) and a cheap platform to run for Honda. It would also serve the purpose of boosting the honda heirarchy which is important for sales. This is like the old days where b series were cross compatible and you worked your way up from a d16 to a b18cr along with a few difference chassis of the way. |
| The Following User Says Thank You to Calvin27 For This Useful Post: | BatStig (02-03-2017) |
#148 |
Drives: 2014 WRB BRZ 6MT
Shouldnt they make a new Honda in the year 3000 instead? it seems more appropriate and call it S3000
| The Following User Says Thank You to ChimpMania For This Useful Post: | funwheeldrive (01-31-2017) |
#149 |
Drives: 2003 S2000, 2008 Fit
#150 | |
I just did some research on the L15B7 and K20C2. It appears that the L15B7 is vastly underrated at "176hp", it is easily a 190-200ish hp engine on 87 gas, and probably 230hp with a tune. The bad part is that the EX-T Civic weighs 110 lbs more than the LX Civic, and the only things they added were some sensors and of course the engine. I imagine that the turbo would allow a few pounds to be taken out of the muffler for equal loudness, and the transmission might be a little heavier, so I'll call it a 90lbs difference. The K20C is "lighter than the previous generation", which is the R18. The R18 was probably around 230-240lbs with all fluids, so I think you can probably say the K20C is something like 230lbs, which is insanely light. Turns out the K20C also seems to have some potential that Honda hasn't been advertising, because it makes peak power basically right at the rev limiter, and it has the same 86mm bore and stroke as the K20A. If you add 90lbs to 230, you get 320lbs, which is a fairly normal weight for a turbo 4, though a bit on the heavy side for a 1.5L. So it's possible the K20C is actually even lighter, which would be amazing. The integrated exhaust manifold is not good for power, but you can overcome that with a Rotrex. If Honda builds this car, they should just grab the K20C2 from the Civic, fit 12.0 compression ratio pistons, spec 91 fuel, and raise that silly 6700rpm rev limiter, which should get close to the 200hp mark from the factory. It seems like a fantastic engine as is, and has much of the potential of the K20Z3/A. With an engine this light, keeping the curb weight under 1100kg should be a piece of cake. |
| The Following User Says Thank You to serialk11r For This Useful Post: | WolfpackS2k (02-03-2017) |
#151 | |
Drive From Home
Drives: BRZ STI Performance
#152 |
Drives: Ap2
I was under the impression that Toyota ecu is tough to break for any flash, you can only go piggy back.
| The Following User Says Thank You to Who8myrice For This Useful Post: | daiheadjai (02-02-2017) |
#153 | |
Drives: '22 Tacoma, '19 Macan, '22 BRZ
#154 |
That is a huge reason. You have to spend a lot more money on a standalone or piggyback, which sucks. The user named "Gouky" who has made 2GR swap kits for the SW20 MR2 has managed to crack the 2GR and 2AR ECUs though, so Lotus Evora, Exige V6, and Toyota Camry drivers can have some moar powah for cheap now haha.
| 2002 Honda S2000 71k miles! | MrFRsLa | Cars for Sale/Trade | 10 | 07-26-2012 06:46 PM |
| The Real S2000 Successor | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 10 | 02-12-2010 02:21 AM |
