86WORX
Old 07-06-2019, 10:27 PM   #15
radroach
Drives: car
@Calum He's talking about the snout that the bearing rides. Somebody should post the part number.
Old 07-06-2019, 10:35 PM   #16
Ultramaroon
fabulous
Ultramaroon's Avatar
Good idea. I'd do it if I knew how.
Old 07-06-2019, 10:47 PM   #17
Abaier
Drives: 2015 Subaru BRZ Limited
just gett'n broke in
Unless, that is,... OP, would you say it's possible that you are in the habit of goosing it before fully engaging the clutch? So the engine goes "eeeee-awwww" when you dump it? It's a common noob thing that can be hell on clutches over time. Other than that, I bet it's practically new.
Do you mean starting from a standstill? I might be, for probably the first 10k on the car I'd get the rpm's up to like 1-1.5k and let the clutch out slowly to get a smooth start. Now I just get to the catch point and match gas to clutch when starting off.
Abaier is offline   Reply With Quote
Old 07-06-2019, 10:53 PM   #18
Ultramaroon
fabulous
Haha.. no. I'll try to find a video of some noob tracking. It's usually when upshifting aggressively.
edit: not hard to find.
[ame]https://www.youtube.com/watch?v=tVsU4CGgsYw[/ame]
Old 07-07-2019, 12:15 AM   #19
humfrz
I've got the car in for a warranty repair on resealing an oil leak on the timing cover, and since the motor needed to come out I had thought I might as well see if the clutch or TOB needs replacing. Got a call from the dealer today saying they recommended replacing the flywheel, clutch, TOB, and pressure plate, they would only charge me for parts which comes out to $830. To have just the clutch and TOB replaced it would be $256 which I find more reasonable, but they really do recommend doing the whole thing. I have fun with the car, but by no means am I launching it at every street light, racing everyone I see, or doing anything outside of the occasional Sunday morning spirited drive.
I do get a bit of noise from the car when its in neutral which goes away when I push the clutch in, but sometimes when the car is cold or if its cold out I get a bit of squeaking and crunching sounds while pushing in the clutch.
What do you guys thing? I trust this dealer and you know what maybe I haven't been the nicest to this clutch, but I do think its a bit early to be having all of those components replaced.
If the dealer is only going to charge for parts, why would they recommend replacement if they are going to supply the labor for free?
Also, the OP seems to trust the dealer -
Not ALL dealerships are rip offs - just the ones I've been to -
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
churchx (07-07-2019), Mr.ac (07-07-2019), strat61caster (07-08-2019)
Old 07-08-2019, 12:13 AM   #20
jflogerzi
jflogerzi's Avatar
Just get TOB replaced. If you know how to drive stick and are staying NA don't do the clutch or flywheel. Replaced my clutch at 64k due to massive TOB failure (2013) and I could have gone quite a bit longer on the clutch and I am still using my same OEM flywheel. I went with a southbend stage 2 due to being boosted.
2013 Series 10 FRS #553
Old 07-09-2019, 03:07 PM   #21
Abaier
Going with just getting the TOB replaced, thanks for all the help guys! Getting the car back on friday and couldn't be more excited
The Following User Says Thank You to Abaier For This Useful Post:
Ultramaroon (07-10-2019)
Old 07-09-2019, 04:09 PM   #22
maslin
Benz Tech
Drives: 2017 BRZ Premium
humfrz
They're still getting plenty of money. Mark up on parts is significant, often 100-200% +. We have small parts over 800% mark up.
Parts and service keep dealers open. No one is working for free.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
humfrz (07-09-2019), Ultramaroon (07-10-2019)
Old 07-09-2019, 04:42 PM   #23
humfrz
Are you sure you're not working for a pharmaceutical company? -
humfrz
maslin (07-09-2019)
Old 07-09-2019, 04:51 PM   #24
maslin
Benz Tech
humfrz
I wish!
Mostly hardware and little things. Cost us $.75, sells for $6. That adds up over hundreds (thousands?) of parts per month. Mercedes is obsessed with "one time use" fasteners. That M14 caliper bolt could easily shear off if you tighten it twice
The Following User Says Thank You to maslin For This Useful Post:
humfrz (07-09-2019)
clutch, dealer, recommendation, repair, tob
Would it be worth it to replace clutch at 40k miles? hpde_addict Engine, Exhaust, Transmission 6 01-17-2018 12:42 PM
Best independent mechanic to replace clutch? Barre Northern California 2 09-15-2017 03:57 PM
Replace Clutch or Time to Upgrade? Antialias Issues | Warranty | Recalls / TSB 9 11-19-2016 09:44 PM
Low mileage and going FI - Replace clutch or wait? FirestormFlex Forced Induction 8 12-17-2015 12:44 AM
OEM Clutch Replace time JRollar Engine, Exhaust, Transmission 18 06-19-2013 01:25 AM
