Old 07-06-2019, 04:56 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Running with a stock spare?
Pardon the ignorance guys, as i have no experience getting aftermarket wheels flat all my life.
I recently bit the bullet and bought TWS T66Fs in 17x8 +42.
Say I get a flat on a road trip, is it safe to replace any of the flats with the stock 17x7 rim and drive it? What damage or risks do i run doing so?
What am i exactly supposed to do in such situations?
Thanks
leevanf is offline   Reply With Quote
Old 07-06-2019, 06:12 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I have no spare.. just gloop! Space savers are pretty common, they are usually smaller than what is on the car, speed restrictions usually apply. The spare is used to get you to a tyre fitter..
Old 07-06-2019, 06:41 AM   #3
86MLR
86MLR's Avatar
Ensure you put the spare on the front.
Different diameter wheels can/will/may screw your torsen diff.
Have a look at the tirerack website to find the diameters.
Google about using a spare with a limited slip diff.
As for goop, it can screw your tyre, plus useless if you hole your tyres sidewall.
As for space savers, fine if you are local, but, when you are 300km from home, on a Sunday arvo, a space saver is a pain in the arse.
I am a advocate for full sized spares when on the street.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 07-06-2019, 06:51 AM   #4
leevanf
leevanf's Avatar
Thank you. Say im running 17x8 PS4s on all sides, and have a stock 17x7 oem wheel with primacy.
Then i bust a rear tire, so i should just swap the front to the rear, then replace the front with my 17x7 oem spare. Will i be safe in highway speeds up to 100kph?
The Following User Says Thank You to leevanf For This Useful Post:
norcalpb (07-06-2019)
Old 07-06-2019, 07:09 AM   #5
86MLR
86MLR's Avatar
What are your tyre sizes mate?
???/?? 18
215/45 17
Old 07-06-2019, 07:14 AM   #6
86MLR
86MLR's Avatar
215/45 17 primacy hp = 24.7" diameter
Old 07-06-2019, 07:29 AM   #7
86MLR
86MLR's Avatar
Apparently, google says, any more than a 3% difference is bad.
Old 07-06-2019, 08:45 AM   #8
leevanf
leevanf's Avatar
It will be the same diameter.
My 17x8 will be on 215/45/17 or 225/45/17 albeit much grippier tires.
What i worry about is thaat will running one 17 x 7 (OEM grip) and 17 x 8 (Grippy tires) in front be dangerous for highway trips back to any nearby tire repair shop?
Old 07-06-2019, 12:25 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
Not unless you're going sideways the whole way
JD001 (07-06-2019)
Old 07-06-2019, 01:49 PM   #10
norcalpb
norcalpb's Avatar
Not at all, just stay below 55mph or whatever that is in km/h.
I’ve thought about using the goop as an alternative to the spare tire but I hear it makes an insane mess that you’ll have to deal with once you get to the tire shop.
I think spare tires are good for only 50 miles. I put 25 miles on mine so I assume I have 25 safe miles left. However this is the rule not the exception. I had a buddy blow a tire out at a track day and he drove nearly 200 miles home without a problem.
Old 07-06-2019, 02:46 PM   #11
leevanf
leevanf's Avatar
Thanks, im not sure about the range, but for the brz, my spare is a full size oem. That should mean i can use it above 50 miles right?
Old 07-06-2019, 02:47 PM   #12
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Read your manual regarding flat tires. If you ever have a flat tire on the rear you'll need to put the front wheel on the rear and the spare on the front.
Oh and holy flying cows Batman!
You ask about using a spare tire? LoL.
Old 07-06-2019, 02:50 PM   #13
leevanf
leevanf's Avatar
Thanks i got that part, my question was more about will there be a problem running on the highway, with a 17x8 and 17x7 (oem) in front?
Old 07-06-2019, 03:02 PM   #14
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
No problem. Been that way for the last 70+ years.
Space saver spares are always thinner than the wider oem wheels. Like I said it's been that way for the last 70+ years across the whole automotive life
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 09:36 PM
Anyone Have Spare Stock Taillights/Rear Fog I Can Borrow? AdamBomb518 Mid-Atlantic 5 02-25-2014 04:07 PM
Anyone have spare stock wheels rims for BRZ laying around? PPX FR-S / BRZ vs.... 0 12-02-2013 08:36 PM
Brz Flat - spare stock tire anyone? joergasm CANADA 3 05-30-2013 01:52 AM
Want to Buy: Stock Wing Mirror (LEFT) Anybody has a spare? kaychew AUSTRALIA 0 03-15-2013 03:11 AM
