#15 |
Drives: 2013 frs red
Bright side is you'll probably get a new motor out of this.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Outlander (07-16-2019) |
#16 |
If they found and removed sealant, damage done. They're just buying time now
#17 | |
Drives: 2013 Scion FRS 6-speed
My only advise is, keep taking it back to Toyota until they fix it. Took me about 6 more visits after they did the recall repair to get it done right. Patience is key. Good luck! Sent from my SM-G892A using Tapatalk |
| The Following User Says Thank You to FRS13_ For This Useful Post: | Outlander (07-16-2019) |
#18 |
Drives: 2013 scion frs
Thanks, everyone for your feedback again. This is defiantly a frustrating experience for anyone dealing with post recall issues. Here is a video from under the hood. It sounds like is coming from the passenger side middle way back. Nowhere near the high-pressure fuel pump.
Any last thoughts based on this video before I bring it back in would be appreciated. |
#19 |
fabulous
It's your vacuum pump. You were centered right on it at the beginning of your video. Watch the area for oil leakage after they fix it.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Outlander (07-16-2019) |
#20 |
Sorry for prior posts. I didn't know it was vacuum pump noise.
#21 |
Thanks, so is that also a recall item. Not sure why noise was not there prior to recall for j02 is it possible that somehow trigger this? I am worried that tech repeatedly say this is fuel pump since week 1 after recall "fix" 5 repairs later. When noise is on other side of engine bay.
#22 |
fabulous
I don't really know. I haven't gone back to review the procedure but they did have to remove the cams. Maybe they buggered something on reassembly.
#23 | |
Drives: 2019 Mazda Miata RF
| The Following User Says Thank You to Gunman For This Useful Post: | Outlander (07-16-2019) |
#24 |
Taking in tomorrow will update the thread when I know any updates. Thanks, everyone again.
#26 |
Well car is still in shop they have found issue with broken o ring on the vacuum. But seems it's more complicated then just that. Don't have many details other than they pulled engine a few times. And breaking did not seem to have any effect on this issue.
| The Following User Says Thank You to Outlander For This Useful Post: | Gunman (07-16-2019) |
#27 |
So car is finally back home and so far so good. They replaced two broken orings one that was on the vacuum pump and a spark plug that was maybe misfiring. Thanks to everyone for feedback and encouragement. I will update if anything changes. Everyone who help find this issue I'm beyond grateful.
#28 |
fabulous
Glad they were able to get it sorted out for you. Best wishes.
| Tags |
| noise, post recall, sealant, ticking |
| She lives once more! (post-recall damage) | BlackOptics | Northwest | 9 | 03-22-2019 07:53 AM |
| Loud ticking from engine | Norotor | Issues | Warranty | Recalls / TSB | 8 | 04-24-2018 02:45 AM |
| perrin catback resonated - loud enough or too loud? | theflathead | Engine, Exhaust, Transmission | 33 | 01-22-2018 06:46 PM |
| alright my tenth post so i can officaly post in the marketplace | destiny86 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-04-2016 01:49 PM |
| Engine is making a loud ticking with Redline 0w20 | KevinBRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 07-29-2013 10:34 AM |
