86WORX
Old 01-30-2021, 07:32 PM   #57
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Originally Posted by solidONE View Post
1.5* of camber eh? I wonder how much caster it gains when orientated north/south postition.
Probably a full degree
BlueWhelan is offline   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
solidONE (02-01-2021)
Old 01-31-2021, 04:24 PM   #58
jflogerzi
jflogerzi's Avatar
Originally Posted by botbs View Post
Anyone have issue on the pedders top hat? I am about to purchase one. Just want to see if it has issue like the Whiteline Comp C top hat.
I am currently using STI Group N (-0.9 camber) and was using Verus Top Hat (too much noise). I want my -2 or at least -1.5 back.
Thanks
I am using them with no issues. Got -2.3 up front and -2.2 back with LCAs
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
botbs (02-08-2022)
Old 02-01-2021, 07:24 PM   #59
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've installed the Whiteline anti-lift kit along with the small bushing of the same material. Supposedly .5 of caster on each side. I could not verify the caster using string alignment. Something about it i dont like, aside from clunks that appeared after installing them. Maybe too firm?
It does seem to turn in a bit more willingly, which I like. I have yet to isolate the clunking noise, so I cannot really blame the bushings... but I think its the bushings.
Who has pedders top mount and want to try this out? Rotate the tops 120* toward the firewall for the caster? 1 entire degree might be too much, but we wont know until someone tries.
Intent > Content
Search this Thread:
Advanced Search
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 05:35 PM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 10:06 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 06:03 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
