86WORX
Old 11-01-2019, 10:14 AM   #43
Racecomp Engineering
Looking at your first and latest alignment, I'm a little confused. Are your left and right tops oriented the same way?
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
cjd (11-03-2019), Tristor (11-01-2019)
Old 06-13-2020, 11:17 PM   #44
7 skulls
Drives: 2014 scion frs
Time for an update. I've had the car back on the road for about 6 weeks now (after winter) and am definitely getting accelerated wear on the inside of my MPSS. 2.5 neg camber might be too much for a daily driver it seems. It's a shame because the car responds beautifully with a ton of front grip.
How is everyone else doing as far as tire wear and camber?
Seems like I have 3 choices now: find another shop and check the original alignment, replace the pedders top hats with stock and keep the stock camber bolts or replace the stock camber bolts with regular ones and keep the pedders.
7 skulls is offline   Reply With Quote
Old 06-14-2020, 05:57 AM   #45
churchx
churchx's Avatar
Drives: 2014 GT86
Sounds weird. Just 6 weeks of summer daily driving with -2.5 front camber enough to wear noticeably inside of tires? Unless you drove 10K miles, imho something is off. DD wears relatively very slow compared to track, and for many front camber upto similar numbers didn't produce significant camberwear.
The Following User Says Thank You to churchx For This Useful Post:
7 skulls (06-14-2020)
Old 06-14-2020, 10:58 AM   #46
7 skulls
Just checked my tires again. Easy to feel the feathering on the inside of the front tires.
Old 06-14-2020, 01:58 PM   #47
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
That's more symptom of toe in, not camber. How many miles have you put on the tires since zeroing out the front toe?
Speaking of toe, the rear passenger side is slightly toed in, but the rear driver side is toed out. Does the car pull slightly to the right when you let go of the wheel?
BlueWhelan is offline   Reply With Quote
Old 06-14-2020, 02:49 PM   #48
7 skulls
Yes, I agree. Less than 1500 miles since the last alignment.
The car tracks perfectly straight when I let go the wheel and perfect wear patterns on the rears.
Old 06-24-2020, 09:24 PM   #49
7 skulls
OK. After some research on NASIOC, I decided 2.5 deg. negative camber was causing my tire wear. (If you are running high negative camber and have no wear problems, excellent.) So I pulled my subaru camber bolts and replaced then with the thicker stock bolts, leaving only the pedders top hats.
See todays alignment below. My toe was good so most of my wear came from camber. Yes the front camber side to side is not exact (still half the total allowable difference and better than what the car came with). For a street vehicle, can't see it making a difference.
No macpherson strut (stock) car will ever have zero toe on the highway (bushings, mounting points will flex). High negative camber will accentuate this. Add in, highway miles and abrasive, heavily worn pavement, I got inside tire wear real fast. If I lived closer to the capital and could auto-x every weekend in the provincial series, maybe more camber would be fine. As it was, no amount of back road carving would even out the wear. At -2.5 camber, I could never feel the front tires begin to roll, but now I can feel them begin to set deeper into their contact patch. Not like the stock 0 camber where the tire will roll over and push.
If you are looking for some more front camber and are worried about aftermarket camber bolts slipping, the subaru camber bolts (non-eccentric) will give you about -1 deg. It will be harder to exactly match camber side to side but there is no fear of slipping. The pedders top hats are good for -1.2-1.5 deg. Again not able to fine tune but again no worries about slippage.
Old 10-27-2020, 02:29 PM   #50
bhmax
Drives: 13 BRZ, 16 FiST, 05 WRX
Thanks for all the info. I’m about to go from two sets of camber bolts to the Pedders mounts and one set of camber bolts. Being weird, I looked at the instructions. It says ensure the OE conical washer is installed between the top spring hat and strut mount. I don’t currently have a washer there, and the service manual doesn’t show one. Maybe being a WRX fitment also, those cars had one?
bhmax is offline   Reply With Quote
Old 10-27-2020, 03:09 PM   #51
That is correct...our OE conical washer is built in to our OE upper spring perch.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
bhmax (10-27-2020)
Old 11-02-2020, 03:41 PM   #52
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
1.5* of camber eh? I wonder how much caster it gains when orientated north/south postition.
Intent > Content
Old 01-29-2021, 12:12 PM   #53
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Anyone have issue on the pedders top hat? I am about to purchase one. Just want to see if it has issue like the Whiteline Comp C top hat.
I am currently using STI Group N (-0.9 camber) and was using Verus Top Hat (too much noise). I want my -2 or at least -1.5 back.
Thanks
botbs is offline   Reply With Quote
Old 01-29-2021, 02:39 PM   #54
BlueWhelan
BlueWhelan's Avatar
Thanks
You’ll be fine. It’s like the Comp C, but done properly. You’ll need two, obv.
The Following 2 Users Say Thank You to BlueWhelan For This Useful Post:
botbs (01-29-2021), Calum (01-29-2021)
Old 01-29-2021, 07:43 PM   #55
7 skulls
Thanks
No problems here.
The Following User Says Thank You to 7 skulls For This Useful Post:
botbs (01-29-2021)
Old 01-30-2021, 06:21 PM   #56
churchx
churchx's Avatar
Drives: 2014 GT86
Same here (~15K km, 5 trackdays, 2 years. Yeah, driven less now due all that lockdown stuff). Pitty that WL botched. We could have had product of such type 7 years ago.
Calum (01-31-2021)
Search this Thread:
Advanced Search
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 05:35 PM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 10:06 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 06:03 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
