#197 |
Drives: 2019 BRZ Sport-Tech RS
WRX STi wheels are a different bolt pattern and have a much more positive offset so that car must have wheel adapter spacers on it.
| The Following 2 Users Say Thank You to N_Raged For This Useful Post: | NaturallyAspirated (08-02-2020), Zacharary (08-02-2020) |
#198 |
Drives: '13 BRZ in WRB--let's mod!!!
18x9.5 Enkei TS-5 5x100 +45
Will these clear? Did search but didn't see these listed. My car has coilovers, so that issues there. ALSO... Is there an 18x10 +43-45 lightweight wheel out there that will clear the Brembos (other than going to a Forgeline, CCW build, etc)? Building the car to a class where size matters lol
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. Last edited by GTB/ZR-1; 08-02-2020 at 03:12 PM. |
#199 |
Drives: 2019 BRZ w/ PP
Yup those are ~2012 STi wheels by Enkei 18x8.5" +55 offset with 5x114 bolt pattern. My guess is that there is at least a 25mm thick spacer/adapter to convert it from 5x100 to 5x114.
#200 | |
Drives: 2020 BRZ Sport-Tech RS
However, @Nesh did make it work with his setup so maybe there is hope! |
#201 | |
Drives: 2022 GR86
b) Any big wheels will make your car look like a monster truck on stock suspension. |
#202 |
Drives: 2017 Golf R
#203 | |
Appreciate the help! Learning so much and it is so invigorating. That's the plan! |
#204 | |
Drives: 2017 Golf R
(also, congrats on the BRZ RS, fellow canadian and RS owner! )
#205 | |
Drives: 22 BRZ limited
| The Following User Says Thank You to dragoontwo For This Useful Post: | N_Raged (08-06-2020) |
#206 | |
Drives: 2017 Golf R
#207 |
#208 |
Thanks, I have OZ Ultraleggera's in the same size and offset with 225/45R17 tires and only have 9/16" of clearance to the strut. I haven't added any camber bolts yet so I was worried about clearance when I do put in camber bolts. It's a bit too close for comfort given the tire flexes in and out during cornering.
#209 |
Drives: 2014 GT86
Tire flexes in and out on contact patch with ground. Unless your wheel bearings are shot with insane play, tire sidewall should rotate at same distance above. If clearance is sufficient along compress/droop travel of suspension/wheel/tire, tire sidewall flex shouldn't be to worry about.
| The Following User Says Thank You to churchx For This Useful Post: | N_Raged (08-06-2020) |
#210 |
I wish APEX made 17x8 wheels.
- Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
| Tags |
| brz, performance package, wheels |
| Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 09:46 AM |
| Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 09:06 AM |
| Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 09:31 AM |
| What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 06:15 PM |
