#71 |
The Dictater
Drives: '13 Red Scion FRS
I wonder how sway bars fatigue over time.
#72 |
The Dictater
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#73 |
Drives: 2017 BRZ PP, 2004 WRX
Bumping this from the dead.
I run in street class autocross and will have 225/45/17 RT660's. I've run the car two years on the stock front swaybar with A052's. Would the Perrin 19mm which is 25-72% stiffer than stock, or 22mm which is 130-218% stiffer work better with the Sachs dampers? I'm trying to keep the limited camber we can get in check while limiting body roll, but not go too stiff that it understeers a ton.
#74 | |
Drives: '23 BRZ
I was wary of understeer just going with a front bar, glad I went this route. |
#75 |
scca street class autox only allows one bar change, iirc the strano bar was 19mm which leads me to think that the 22mm would be overkill given how soft the rest of the system is.
Or spend $$$ on Karcepts. |
| The Following User Says Thank You to strat61caster For This Useful Post: | timurrrr (02-18-2022) |
#76 | |
Ran it last year on the track and autocross at full stiff and would definitely recommend running any 22mm solid bar on soft. I was experiencing a lot of mid-corner push on the track. It's bad enough that I sometimes feel it on the street during low grip situations (i.e. rain/snow). Last edited by SCFD; 02-17-2022 at 12:05 AM. |
| FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars | armyoffoo | Brakes, Suspension, Chassis | 10 | 08-08-2018 09:28 AM |
| Oem sway bars | Marks Boosted | Brakes, Suspension, Chassis | 2 | 07-20-2017 08:29 PM |
| WTB F&R sway bars | blkmamba | Canada Classifieds | 1 | 06-04-2017 03:15 PM |
| FR-S stock sway bars compared to TRD bars | babydriver | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-01-2014 10:12 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 07:00 PM |
