Southern California SoCal
View Poll Results: which rim size should I go with
17x8.5 22 70.97%
18x9 9 29.03%
Voters: 31. You may not vote on this poll
Old 05-30-2019, 12:47 PM   #1
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
17x8.5 or 18x9
Im almost ready to buy my volk rims, and the question that keeps coming up is whether I should stick with 17 inch rims or up size to 18's. My main focus on the car is performance and I was under the impression that 17 was the sweet spot for wheel size, but others have told me that the 18's are the way to go. What do you guys think?
mod on
ric342 is offline   Reply With Quote
The Following User Says Thank You to ric342 For This Useful Post:
Leonardo (05-31-2019)
Old 05-30-2019, 01:16 PM   #2
StraightOuttaCanadaEh
Wes
I believe 17x9 is the sweet spot for weight and grip. Having said that, I run 18x9.5 for looks (also planning FI in the future)
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
why? (05-31-2019)
Old 05-30-2019, 01:48 PM   #3
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
If you care about looks, run 18x9.5. You need 9.5s to get that deep concave face. There's no reason to run 18x9, you'll lose the look but won't gain performance.
If 100% function/performance is your game-- 17x9.
Shizuka is offline   Reply With Quote
The Following User Says Thank You to Shizuka For This Useful Post:
why? (05-31-2019)
Old 05-30-2019, 02:10 PM   #4
ayoshioka1
Drives: 2019 BRZ / E36 325is
its all preference at that point. if i were you i would look at different tire manufacturer availability and pricing.
Do you like the small wheel big tire look or vice versa? Also going with 18's it widens up the wheel selection as well. 17's currently are quite limited in selection.
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
The Following User Says Thank You to ayoshioka1 For This Useful Post:
why? (05-31-2019)
Old 05-30-2019, 03:58 PM   #5
D-rek07
I've never heard of going up in wheel size and lower in tire profile as offering any performance advantage. Also, they don't offer 17x9 wheels?
D-rek07 is offline   Reply With Quote
The Following User Says Thank You to D-rek07 For This Useful Post:
Clutch Dog (05-30-2019)
Old 05-30-2019, 04:09 PM   #6
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Konig has a few.. those are the choice autox rims, might not look the very best but ify ou want cheap, reliable and wide? second to none
Clutch Dog is offline   Reply With Quote
Old 05-30-2019, 05:12 PM   #7
BEZO760
Drives: Blue 2016 SCION FR-S
I have wedssport tc105n 17x9 +35 on my FRS. This was even before I got coilovers. So you can run these no problem on stock suspension. Here's a picture with stock suspension
https://www.instagram.com/s/aGlnaGxp...812_1081088320
BEZO760 is offline   Reply With Quote
The Following User Says Thank You to BEZO760 For This Useful Post:
why? (05-31-2019)
Old 05-30-2019, 05:38 PM   #8
D-rek07
Originally Posted by Clutch Dog View Post
Konig has a few.. those are the choice autox rims, might not look the very best but if you want cheap, reliable and wide? second to none
I guess I'm a little confused. You said you were ready to buy Volk wheels but only have the option of 17x8.5 and 18x9?
Old 05-30-2019, 05:47 PM   #9
Clutch Dog
Also RAYS makes this https://www.rayswheels.co.jp/product...=en&wheel=57CR
17x9 id run a 17 due to lowered cost. 18s can get pricey fast.
Old 05-30-2019, 07:13 PM   #10
ayoshioka1
OP clearly doesnt know what he wants lol
Old 05-30-2019, 08:42 PM   #11
strat61caster
strat61caster's Avatar
Drive car hard, replace tires often, 17" tires cheaper than 18" tires, 17x9 is a standard wheel sizing for 245/40/17 (driven by SCCA and TT rulesets, trickle down effect from people copying fast guys in those realms), that tire works on an 8.5" wheel just fine. Go down to a 17x8 for a cheaper 225/45/17 tire, but I think that'd be too stretched on an 8.5" wheel, it'll work, just preferences. 17" wheels are usually cheaper than 18's too. 235's aren't common to split the difference, especially in fast tire compounds, uncommon tire = expensive tire.
It is less of an issue this decade, pushing for larger diameter wheels offered a lot of performance advantages in the past, it wasn't so long ago that 14" was a 'sporty' wheel (the Miata came on 14" wheels up to the launch of the NB when they were replaced with 15's, the AP1 S2000 had 16's) but we're in a sweet spot right now with most cars offering/accepting 17"-19" wheel options that work great.
Shorter stiffer sidewalls respond faster and more consistently, I believe back in the day before radials were common the lower profiles offered better stability at high speeds. Larger wheels also mean more space for larger brakes which in the early days of discs meant more thermal capacity, stop better = faster laptime.
There's a balance to strike, the car was designed around a 17" wheel with a ~24.7" diameter tire, messing with that formula may make the car feel 'off' as now the bushings, suspension, and chassis are working harder to compensate for the reduced tire flex. It could be worth it if you're going down the well of making your car faster but it sounds like you're just getting started so stick with the 17's imho, spend the money on seat time.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
ric342 (05-31-2019), why? (05-31-2019)
Old 05-30-2019, 10:32 PM   #12
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
IMHO 17x9.5 is the PERFECT spec. You stick to the 17inch diameter but also get the 9.5 width that is appealing to most without going to 18s. The only problem is that it is very hard to come by. I’m running 17x9.5 +40 TE37SLs on mine.
OzzyGT86 is offline   Reply With Quote
Old 05-31-2019, 02:03 AM   #13
jaime3
jaime3's Avatar
Drives: Scion FR-S
Stick with the 17s ! Better for performance if that’s what you’re looking for and I’m pretty sure the wheels will look good in either size!
jaime3 is offline   Reply With Quote
The Following User Says Thank You to jaime3 For This Useful Post:
ric342 (05-31-2019)
Old 05-31-2019, 02:31 AM   #14
ric342
FR-S driver
ric342's Avatar
I was thinking of sticking with the current size I have, 245/45/17 and buying another set of the bridgestone RE-71's. The reason I am thinking about going 18 is because it will fill out the car more, but all the mods I'v done on the car had functionality in mind not looks.
mod on
guys with meaty tires and big power, 17x8 vs 18x9.5? brz11b Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-21-2021 03:36 PM
Work Meister S1R 17x8.5 +16 F, 18x9.0 +22 R Manji Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-24-2016 03:03 PM
RPF1 5x100 Group Buy; 17x8 +45, 17x9 +35/45, 18x8+35 & 18x9.5 +38 Exclusive Colors OAKOS Automotive Groupbuys 54 02-04-2014 05:08 PM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 11:49 AM
TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! RavSpec Wheels and Tires 2 07-14-2012 10:37 PM
