86WORX
Old 05-30-2019, 11:35 AM   #15
tomm.brz
Drives: brz 2017 hksv2
do you hav3 a log of a 3rd gear full throttle pull?
Old 05-30-2019, 02:55 PM   #16
incutebus
Drives: Boosted
Originally Posted by DarkPira7e View Post
Where is that hose coming from? If that's a pcv catchcan, your feed from the engine should be going to the top port.
Did you clamp down the hoses UNDER the intake manifold? Here's a glimpse of mine in the middle, you can see a worm clamp on one of the 3 hoses.
Whoa, so the location to where I attached the line for the catchcan is incorrect?
Also, as far as for leaks under the intake manifold that may be a possibility. I did clamp it down but I did purchase a used turbo with lines that seemed too big.
incutebus is offline   Reply With Quote
Old 05-30-2019, 03:21 PM   #17
tomm.brz
if you had a leak under manifod you would notice IMMEDIATELY,and it would stall, and your idle log is good.
when i had a under manifold leak with my supercharger i had so much fuel going on that it literally poured liquid fuel from the exhaust
Old 05-30-2019, 03:25 PM   #18
incutebus
Drives: Boosted
Do you think the positioning of my engine feed on the catch can is incorrect?
I chose the location of where I circled it red.
Old 05-30-2019, 04:55 PM   #19
toast
Drives: 14 BSP Edelbrock BRZ
You didn't get directions for installing the catch can? In your pic the top port is not connected, that seems fundamentally incorrect. We can't troubleshoot this for you if you don't give us more information. Is this can on the PCV line or the CCV side?
-30 STFT does not indicate a leak, the tune is trying to dump fuel into the motor at that point for some reason and the closed loop feedback system is taking the fuel back out (or as much as it can anyway, the max is -29.7%). I think there is either a fat-fingered value in a table or you have a sensor that is feeding bad information to the ECU.
The nipple you keep asking about is in a cold air intake upstream of the MAF sensor? If so it won't cause any issues other than letting in air that doesn't get cleaned by the filter.
toast is offline   Reply With Quote
Old 05-30-2019, 06:02 PM   #20
incutebus
Drives: Boosted
Sorry the nipple that I was mentioning about was on the catch can itself.
When you say the top port is not connected, do you mean the one I circled in red? Or the one at the very top? There's no instructions for installing this so I'm like super confused lol.
Just show a pic of my engine bay
Old 05-30-2019, 07:35 PM   #21
toast
Where do the two ports you do have connected go? I can only see one line in that pic and it looks like it goes to the CCV nipple on the driver side.
Old 05-30-2019, 07:44 PM   #22
incutebus
Drives: Boosted
The top nipple doesn't go anywhere and has a filter on it, the other side of the catch can is just blocked off. The only hose you see connected is the one being routed.
Old 05-31-2019, 09:41 AM   #23
toast
Ok, so you are venting your crankcase breather to atmosphere. That won't cause your issues. It will make your car stink.
What are you doing on the PCV side? You can't plumb the PCV output to the manifold unless you installed a check valve inline.
I still think you have a tune issue.
Old 05-31-2019, 06:27 PM   #24
incutebus
Drives: Boosted
I suppose theres only one way to find out . He still hasn't gotten back to me.
Old 06-01-2019, 11:40 PM   #25
Turdinator
Seņor Member
Turdinator's Avatar
To my knowledge, the way you have the catch can routed is not going to catch anything and when off boost would result in unmetered air getting to your manifold. If you still run a maf that is.
1974 TA22 Celica
2013 86 GT
Old 06-02-2019, 12:23 AM   #26
incutebus
Drives: Boosted
Oh, I didn't know that. Any suggestions?
Old 06-02-2019, 09:37 AM   #27
toast
The crankcase vent is run upstream of the MAF in stock configuration, so it is always pulling in unmetered air.
Old 06-02-2019, 03:02 PM   #28
incutebus
Drives: Boosted
So... about my catch can setup
2017 T86 concerns GTspeedster Issues | Warranty | Recalls / TSB 12 03-29-2018 09:34 AM
OFT Observation and concerns Kayysonie Software Tuning 30 12-07-2016 01:55 AM
e85 concerns Lantana frs Engine, Exhaust, Transmission 6 06-29-2016 04:02 AM
Some Concerns?? KevinYeh BRZ First-Gen (2012+) -- General Topics 14 06-30-2014 05:03 PM
K&N air filter .... any concerns ..?? humfrz Engine, Exhaust, Transmission 3 11-26-2013 02:25 AM
